Zeitronix and Evoscan Boost reading
Old Apr 5, 2010 | 03:17 PM
ant_turbo's Avatar
Anyone havin issues with evoscan and zeitronix reading high boost?
High boosy will not show up in evoscan.....
Old Apr 5, 2010 | 03:24 PM
GregM's Avatar
How high is it reading to?
Old Apr 6, 2010 | 08:29 PM
ant_turbo's Avatar
Well,,, after I did a log I read my Zeitronix LCD and it said peak was 24.5,,
But nowhere in my log does it say 24.5....
Old Apr 6, 2010 | 08:36 PM
RoadSpike's Avatar
no problems here really just a slight descrepency between my zeitronix on the intake and the one connected to the zeitronix about .5psi usually. Reading up to 30psi here.
Note:
Sometimes the zeitronix unit shows data higher than the log because of the sample rate on evoscan. If your unit isn't reading the proper boost then it may not be setup for the right boost sensor.
Old Apr 7, 2010 | 11:51 AM
ant_turbo's Avatar
I am using a zeitronix map sensor..
Note:
Old Apr 7, 2010 | 11:55 AM
RoadSpike's Avatar
So am I on both counts intake manifold and the one directly connected to the zeitronix unit itself.
I still had to setup the zeitronix sensor on their own unit to use the 5bar settings instead of the 3.5bar ones.
Old Apr 7, 2010 | 01:50 PM
Boosted Tuning's Avatar
Did you happen to reset your LCD or is that peak an old one?
Old Apr 7, 2010 | 07:37 PM
ant_turbo's Avatar
I reset it before my run,,,,,,
Giulio Piloni
Jul 10, 2017 03:16 PM
Casey Robertson
Mar 22, 2016 04:32 PM
4g63_guy
Jun 11, 2009 07:33 PM
evil mechanic
Jan 8, 2007 12:36 PM
vboy425
Nov 21, 2005 07:42 PM
