Can A ROM Go Bad While In The Car?
Old Apr 6, 2010 | 09:58 AM
bboy_RES's Avatar
can a ROM go bad randomly when being used? i reflashed my ECU last week and had to disable the Immobilizer code. my car started up fine. yesterday after class i tried to start my car and it wouldn't start. it cranks, but it wont turn over. i checked all my fuses and concluded that it wasn't a mechanical/electrical issue. i figured it might be a software issue. i tried to reflash my ECU, but it wouldn't let me read/write in ECUFlash. i tried using ECU Unlocker, but that didnt work either. so can a ROM randomly go bad while being used? that's the only thing that i can think of that could be the reason why my car wont start.
Old Apr 6, 2010 | 11:05 AM
wip's Avatar
wip
How's the battery?
Mine does the exact same thing if the battery is pretty low.
Old Apr 6, 2010 | 11:19 AM
Kracka's Avatar
If your battery voltage drops too low you won't be able to write to the ECU.
Old Apr 6, 2010 | 11:34 AM
nightwalker's Avatar
I use what I learned from factory flashing, and it's to ensure the battery has 12 volts + before you flash. Guys will even hook a battery charger up to the battery to make sure it doesn't drop below 12 volts. My instructors always warned about "bricking" the ECU when flashing a computer without the proper voltage.
Old Apr 6, 2010 | 02:30 PM
Asmodeus6's Avatar
I'll also side with the voltage crowd for now pending any other information.
Some bizarre beta versions of patched roms have at times gotten funky - but it was usually bad from the get go and it just takes a little while for you to notice the issue, or drive the car to where you run into it. I've never had a flash just suddenly go 'bad'. But I have had a flash - flash bad maybe once or twice.
Next up is the possibility of a fuse went that took out the power to the EFI but not the starter.
Your other option is that your ecu managed to take a dump.
Old Apr 6, 2010 | 10:59 PM
bboy_RES's Avatar
im charging the battery right now. i'll let you guys know how it turns out. thanks for the replies.
Old Apr 7, 2010 | 11:51 AM
bboy_RES's Avatar
okay so charging the battery didnt work. any other ideas?
Old Apr 7, 2010 | 12:27 PM
gsrboi80's Avatar
Seen it happen because of a bad cable
Old Apr 8, 2010 | 12:29 AM
bboy_RES's Avatar
just tested the cable on a friend's Evo IX and it worked perfectly. i'm picking up a used Evo IX ECU later today. hopefully that solves my problem.
Old Apr 8, 2010 | 12:50 AM
evo ace's Avatar
When it comes to electrical and ECU tuning, make sure you have someone that is credible and knows what they are doing.
Old Apr 9, 2010 | 09:02 PM
bboy_RES's Avatar
wow so i replaced the ECU and it still doesnt want to read/write! i'm trying to check the INIT/OBD II connectors right now to make sure the wires are still good.
Old Apr 10, 2010 | 06:05 PM
bboy_RES's Avatar
fixed it. fuse #8 under the hood kept blowing. i guess one of the wires got crossed when i extended my o2 sensor wires.
Old Apr 11, 2010 | 11:06 AM
wip's Avatar
wip
Good stuff, glad you got it sorted
