about Ecu Flash and wb02
if you have everything installed: use the click at the top of the evoscan header and the "external wideband" box.
shouldn't need the disk for anything, and if you have not bought the wideband then I would suggest the lc-1 over the lm2.
with the lc-1 just read the manual and it will work..... assuming you have wired it up correctly. the power/ grounds are very finicky.
