Knock Then No Knock
Old Apr 27, 2010 | 11:53 AM
SyZyGy1394's Avatar
Originally Posted by hediki12
what load are you logging?
Or even better. Post the log.
Old Apr 27, 2010 | 12:04 PM
hediki12's Avatar
yes what he said.
Old Apr 27, 2010 | 01:04 PM
rdtech's Avatar
is lean spool disabled?
Old Apr 27, 2010 | 02:01 PM
Evokid8's Avatar
how do i do that?
Old Apr 27, 2010 | 04:15 PM
hediki12's Avatar
Originally Posted by Evokid8
how do i do that?
umm put the .csv file into a .zip format. if you have winrar the rite click your desktop then select new then winrar ZIP archive . then double click teh created file and add your csv formated log. then atach using the attach button above (looks like a file clip)
or
take a pic of the screen . open the log make sure its the main window. and print screen. paste it in windows paint. and save as PNG . do so until you have the whole log saved (just the 100% throttle part of course) and attach and upload in the same way stated above.
Old Apr 27, 2010 | 07:14 PM
Evokid8's Avatar
or
loaded!
File Type: zip
Old Apr 28, 2010 | 08:05 AM
Raptord's Avatar
You are logging way too many things, there is a 2-300rpm gap between every log entry which is unacceptable to correctly diagnose your problem. Uncheck everything in evoscan except what you really need, namely:
- RPM
- Speed
- 2byte Load
- Timing advance
- knocksum
- TPS
- injector duty cycle
- AFR
- Boost
That's it. All the other stuff you're logging is just slowing down your laptop. Also uncheck the "log data to screen" option in evoscan (in the logging menu).
Unfortunately your log is next to useless in it's current form. When you have faster logging we'll be able to help you much better.
If you want any help with anything, like setting up 2byte load or getting faster logging, you're more than welcome to PM me, I was in the same boat not too long ago and I'll be glad to help you out!
Cheers!
90zcrex
Nov 11, 2012 04:40 PM
justboosted02
Dec 16, 2008 01:25 PM
evo828
Mar 4, 2008 11:22 AM
Jack_of_Trades
Oct 30, 2007 10:52 AM
spdracerut
Jan 14, 2007 12:51 AM
