Knock Then No Knock
Old Apr 26, 2010 | 05:02 PM
Evokid8's Avatar
Knock Then No Knock
ok i am very confused, im logging with evoscan and doing the usual 3rd gear pulls.
i do one run (1-2 counts of knock) so im like okay cool....
TPS was at 100% from 2500-redline.
Second run (10-14 counts of knock!) no timing was adjusted and i was hitting the same loads! but the TPS wasnt as high 100% 4500-redline
is there something wrong? both pulls were done back to back with nothing changed to the ecu.
Old Apr 26, 2010 | 05:06 PM
MR Turco's Avatar
same load points? Sounds like you need to clean up timing.
Old Apr 26, 2010 | 05:25 PM
Evokid8's Avatar
80 spiking 162@3400 RPM going down to 130, i just dont know why one pull would be fine then the next its all hell. 162@3400 had the highest count of knock.
Old Apr 26, 2010 | 05:55 PM
Raptord's Avatar
Have a similar problem with my own Evo, still haven't figured it out.
Old Apr 26, 2010 | 07:11 PM
erickponce's Avatar
I also had this problem and I've pretty much got it fixed. All I have been doing is making the degree difference closer between cells so that it doesn't have big jump changes in timing (smooth out the timing in the problem areas)
Old Apr 26, 2010 | 08:31 PM
fryedchikin's Avatar
How did your AFR's compare between the 2 runs ?
Old Apr 26, 2010 | 10:45 PM
Evokid8's Avatar
no wideband =[
Old Apr 26, 2010 | 11:44 PM
T2Small's Avatar
Yeah you could easily be surfing to neighboring cells in the map. Also if you are doing back to back runs you could have heat soaked your intercooler.
Old Apr 27, 2010 | 08:03 AM
Evokid8's Avatar
well i bought the car stock with a modded map so i know its been modded before, i added bolt-ons but should i load the stock map into the car and work from there?
Old Apr 27, 2010 | 08:09 AM
Jorge T's Avatar
Originally Posted by Evokid8
no wideband =[
No telling without a wideband. It could be overly rich or lean induced knock.
also your 162 load is low not sure what is going on there. What are you using to log?
Old Apr 27, 2010 | 08:27 AM
Evokid8's Avatar
evoscan
Old Apr 27, 2010 | 11:27 AM
T2Small's Avatar
Unless you are overly rich or lean, I would suspect a timing issue before fueling.
Old Apr 27, 2010 | 11:41 AM
hediki12's Avatar
wait why is your evo only hitting 160 load and dipping to 130 by redline?
Old Apr 27, 2010 | 11:49 AM
SyZyGy1394's Avatar
Could be stock boost to explain the redline part? Remember that it tapers down to something like 12 psi at redline. When I was on the factory maf and tapered to 21psi at redline it was around 200-210 load...
Old Apr 27, 2010 | 11:51 AM
hediki12's Avatar
what load are you logging? ie 2 byte ,1 byte ,load calc?
