What wideband for install on Evo 8
Hi guys
I have just ordered my evo 9 ecu pins and I have my apexi 3 bar map sensor ready
What wideband do you guys recommend for permanent install?
I was looking at the PLX SM AFR, about same price as LC1 (seems to be alot of people have issues with LC1)
I want some thing easy to install and discrete, not having silly lights and calibration buttons etc.
I have LM1 and LM2 for doing customers cars
Any help will be appreciated
Phil
Phil
i use an lc1, it is actually my 2nd one. if you have all the wires wired in correctly and have a fuse in line you should not have a problem and if you have a good ground location. i chose to ground to where the ecu is behind the glove box and it has been working without a hiccup in the last 2 months that ive had it installed. the box for the lc1 is under the a/c control unit under the dash so it is a very clean install and i also keep the light and calibration button under there
Noize
12
Apr 12, 2011 08:02 PM
