Evo VIII Ecu (USDM) in Evo IV (JDM)
Old May 24, 2010 | 09:06 AM
RoadSpike's Avatar
Originally Posted by LanEvo IV
My car donīt star!!!
I think that is the inmoviliser but I try to disable but I could not.... I donīt know how =S....
when I run ecuflash I get a read image.. but i donīt find for change the periphery codes, etc... Can you help for explain best way to understand this??'
Apologize for the inconvenience!!!!
Cheers!!!
You read the evo wiki page i linked up a couple posts back right?
1)Close Ecuflash
2) Add the xml to your xml in the evo rommetadata folder
3) Goto the periphery settings and set immobilizer bit to 0
4) Flash car
Old May 24, 2010 | 09:31 AM
LanEvo IV's Avatar
1)Close Ecuflash
4) Flash car
Yeahh, I tried to do that but when I go to the periphery setting itīs not avalibable...
Old May 24, 2010 | 10:06 AM
RoadSpike's Avatar
You must be editing the wrong xml file then.
Open up your RomID.xml and see what it inherits from if its not evo7_base or evo9_base then just add it to the bottom of that xml.
Old May 25, 2010 | 08:05 AM
LanEvo IV's Avatar
Thank you to all, really, thank you very much!!
Finally, I could not start the engine, but I eliminated the inmovilizer. The Ecu itīs ok, the car tried to start, but, when I scanned the Ecu, it gave to me the P0340 code, so, Itīs the cam sensor position.
Today, I will change it and I hope that everything goes out well and the car start!!!!
the I tell you guys how it goes!!!
Old May 25, 2010 | 09:28 AM
RoadSpike's Avatar
Make sure the ecu to the cam sensor is wired in correctly.
Old May 26, 2010 | 07:52 AM
LanEvo IV's Avatar
The car finally start =). But the CEL and other light itīs on! but I donīt care =).
i have another map (for race) but only the HEX not XML and I want to install to my car, how can I do????
Old May 26, 2010 | 01:58 PM
todd6027's Avatar
what are the fault codes and what rom id are you using
Old May 26, 2010 | 03:01 PM
LanEvo IV's Avatar
I use 9653006RS2 and the codes are CEL and a red one.. I think itīs 02 light or I donīt know.
Old May 27, 2010 | 02:28 PM
todd6027's Avatar
the red warning light is the cat overheat light it's not supported on the newer roms , so either join the wires to the sensor (under the drivers seat ) or take the bulb out of the dash , it has no other purpose than to tell you if the cat gets too hot , it was discontinued after the evo4 .
Old Dec 25, 2011 | 01:28 PM
stunt2's Avatar
sorry for bumping this old thread up. going to make similar ecu swap and wonder if E4 and E8 mafs are the same ?
can I just copy over E8's maf Size/Scaling/Compensation tables ?
Old Dec 25, 2011 | 01:50 PM
todd6027's Avatar
no need to change anything
Old Dec 30, 2011 | 04:23 AM
evo_zero's Avatar
I need this. I want to start tuning my IV.
Old Dec 30, 2011 | 06:08 PM
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Send me your mods or specs that have your Evo, maf, injectors, etc etc. this is my email: jonmorera@hotmail.com I can make a rom with no inmobilizer and stocks maps to start your Evo.
Old Feb 12, 2012 | 11:44 AM
stunt2's Avatar
bumping this thread up. got jdm E4 with swapped VIII ecu and rear screen defroster doesn't work. is it something ecu/connection related or shoud I look for the problem somewhere else ?
when turning rear defroster on/off there's slight ticking sound somewhere from under steering wheel. does that rule out ecu/wiring problem and I can say it's turning on but no power reaches till rear screen ?
Old Feb 12, 2012 | 02:32 PM
todd6027's Avatar
defroster has no connection with eng ecu , the click is the defroster relay clicking in , test across the 2 rear window connectors for 12v when switched on if not look for blown fuse
