no lift to shift
Old May 24, 2010 | 06:09 PM
billsIXmr's Avatar
yea thats what i was doing how do i copy over the maps im still confused on this
Old May 24, 2010 | 08:47 PM
drifterific's Avatar
Go to this post that I linked https://www.evolutionm.net/forums/7597107-post2.html and go to the Evo IX section and click the download button next to the rom that you are wanting to flash to your ecu the section will look like this (see below) so you know if you are on the right track. From what I understand Tephra v7 is a prepatched "bin" file with the correct xml definition included when you select the download option. Hope this helps you out.
I do have a question of my own, are the fuel and timing maps just a bigger version of the stock map that you would take from the rom on an unmodified car?
USDM Evo IX
Option 1 88590715 (v7) - Download
Option 2 - Thanks to recompile 88590715 (v7 + Mods) - Download | Mirror
* Setup for JDM MAP and PSI based boost control (mrfred)
* WGDC Correction Interval set to 1 (Stock = 10)
* Max Total Upward WGDC Correction @ 100% TPS set to 0 (Stock = 10)
* EGR System Disabled (mrfred)
* Max Timing Retard set to -20 degrees (tephra)
* FAA bit.10 disabled ("weird unknown" timing pull at cruise)
* FAA bit.09 disabled (cat-warmup ignition retard)
* FBA bit.00 disabled (lean spool)
* FCA bit.09 disabled (EGR Test)
* OBD Inspection set to Pass all tests (acamus)
* Rear O2 Heater patch applied (mrfred)
* Fuel Cut Load Limit x2 and set to 300 (mrfred)
Option 3 - Thanks to recompile, scheides, and bigric09 88591715 (v7 + Mods + Speed Density) - Download | Mirror
* Speed Density Implemented
Old May 24, 2010 | 08:58 PM
nothere's Avatar
drifticic asked
thats right
Old May 25, 2010 | 12:10 AM
sweet thanks for your quick reply.
SagegreenX
Jan 5, 2017 07:56 AM
jaime8754
Dec 6, 2016 11:09 AM
jz
Jun 23, 2006 03:09 PM
snoop
Nov 18, 2004 01:56 AM
anton670609
Aug 23, 2003 11:37 PM
