Help for my RS from the experts:)
Old Jun 3, 2010 | 05:58 PM
  #46
RoadSpike's Avatar
Data gathered so far
Fans
MUT AB
Mask #1 = 0x1
Mask #2 = 0x2
AC Hi:
Mut Command (Actuator 0, Mask 0x1000)
AC Lo:
Mut Command (Actuator 0, Mask 0x800)
Main Fan Hi:
Mut Command (Actuator 0, Mask 0x400)
Main Fan Lo:
Mut Command (Actuator 0, Mask 0x200)
When i activated the fan it used mask 0x1 then added mask 0x2 later perhaps the coolant temp decided this. Despite what command I set. I'll discover which settings does what later with a running test and will just simply pay attention to the fan and variable timing with the AC On and then Off.
Fuel Pressure Solenoid:
Mut AB
Mut Command (Actuator 0, Mask 0x8)
Mask 0x4
Evap Solenoid:
Mut B2
Mut Command (Actuator 0, Mask 0x4)
Mask 0x4
Fuel Pump:
Mut B6
Mut Command (Actuator 0, Mask 0x2)
Mask 0x20
Old Jun 3, 2010 | 09:01 PM
  #47
Jack_of_Trades's Avatar
Kinda late to the party and i just skimmed over it. So you just want the fans on constant once started? Just use the starter signal output (pin 71) from the ECU to trigger a DEI 528T Delay Timer to activate the fans a few seconds after cranking.
Old Jun 29, 2010 | 12:58 AM
  #48
RoadSpike's Avatar
Just updating this to let you all know my life has become needlessly complex leaving me no time to do work on this rom. In the process of trying to get a new house and the number of steps is quite daunting. If I do find additional time to work on the rom I'll let everyone know
Old Jun 29, 2010 | 06:42 AM
  #49
David Buschur's Avatar
roadspike, I appreciate everything all you guys do. Sorry to hear your life has become so complex, I hope it's not completely overwhelming!
Old Jun 29, 2010 | 09:22 AM
  #50
RoadSpike's Avatar
Its not that bad just eats away at my free time.
Old Jul 8, 2010 | 12:38 PM
  #51
mullen's Avatar
david just out of curiousity how are planning on running sd? are you running it directly from the ecu or are you using a harness similar to spoolinup's
Old Dec 8, 2010 | 08:55 AM
  #52
mullen's Avatar
did you ever make any progress with this?
Old Dec 8, 2010 | 04:16 PM
  #53
Nope, as far as I know it was never all finished. I'm happy enough with the Haltech, I don't think I'll switch to anything else.
Old Dec 8, 2010 | 04:17 PM
  #54
mullen's Avatar
if you master the sd tuning i could tell you atleast 5 guys i know personally who bring there car...
Old Dec 8, 2010 | 06:25 PM
  #55
psphinx81's Avatar
david will be tuning my car on SD this spring. full buschur built car..
Old Dec 10, 2010 | 01:12 AM
  #56
BISHILVR's Avatar
Why not just have your water pump come on with the cooling fans and then set your cooling fan on temps a little lower than what you normally would?
Old Dec 10, 2010 | 06:33 AM
  #57
That idea will not work for a few reasons.
Old Dec 10, 2010 | 11:06 AM
  #58
BISHILVR's Avatar
Yeah, now that I think about it, the temp sensor has to have coolant flow past it to know the temperature to turn the fans on...duh! This shouldnt be that hard to come up with, maybe I can work on it.
Old Dec 10, 2010 | 12:30 PM
  #59
mullen's Avatar
to my knowledge david said he had no interest in tuning on sd
Old Dec 10, 2010 | 06:18 PM
  #60
I have tuned a few SD cars Mullen.
