timing help
Old May 27, 2010 | 10:01 AM
sharkm87's Avatar
timing help
i also had another post about this yesterday...
but i'm gonna try to post here as well...basically i'm not sure what could of triggered this to happen but if i freely hit gas my timing will go to 50 degress across board...if i apply any type of boost knock counts jump in 20's and timing is also in 20's.....which obviously is not in my map...matter a fact no where in the map does it say 50 degrees..
not sure if an option was selected or if anyone ever seen this before??..
no boost leaks...plugs also are still gapped .26 like normal and look fine....thinkin thres some option i may of enabled inadvertently..i'm not sure
Old May 27, 2010 | 11:09 AM
sharkm87's Avatar
bump...now its threw a random misfire...had same cams in for 3 years and never had this issue...
i seen all the threads bout disabling that, but would that cause timing to act crazy as it is?
anyone think its wires?? or maybe change plugs even though they look fine?
Old May 30, 2010 | 08:45 PM
hediki12's Avatar
logs please
tps, rpm, load, knock sum, umm timing advance
mrfred
Feb 26, 2022 06:16 PM
WW14
Cobb AccessPORT
Mar 6, 2017 04:08 AM
2gboosted
Apr 23, 2016 03:03 PM
10isace
Mar 13, 2016 03:09 PM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
