V7 PSI based boost control
Old Jul 31, 2012 | 03:31 PM
  #61
211Ratsbud's Avatar
all of my pointers seem to be correct but I see no corrections made to my WGDC. Any input?
Old Jul 31, 2012 | 03:49 PM
  #62
charlie.tunah's Avatar
Have you double checked the map sensor scaling in all of the psi related tables? Correction, Desired psi, and the adder.
Old Jul 31, 2012 | 05:11 PM
  #63
211Ratsbud's Avatar
Yup it was wrong gonna check it again in the morning
Old Aug 1, 2012 | 03:08 AM
  #64
That has gotten me more than once.
Old Aug 1, 2012 | 03:52 AM
  #65
211Ratsbud's Avatar
Lol i saw that above and I said doh!
Old Aug 1, 2012 | 02:24 PM
  #66
211Ratsbud's Avatar
I see only two. Desiredand adder. What correction? Didn't see map scaling there
Old Aug 1, 2012 | 02:32 PM
  #67
Boost Error Correction (PSI)
my last few roms show "BoostErrorPsi OMNI4barMAP" as the scaling
Old Aug 1, 2012 | 03:33 PM
  #68
211Ratsbud's Avatar
Roger that mine just said boost error... Changed to boost error psi omni 4 bar
Old Aug 1, 2012 | 03:41 PM
  #69
Was one of the other 2 tables scaled improperly? The last couple SD 2.0 roms Ive tried had random default scaling in them.
Old Aug 1, 2012 | 04:16 PM
  #70
211Ratsbud's Avatar
the other two had JDM 3 bar
Old Aug 1, 2012 | 05:15 PM
  #71
211Ratsbud's Avatar
Every time I save it it goes back to jdm 3 bar
Old Aug 2, 2012 | 03:42 AM
  #72
Make sure you change both tabs. You should have a tab that matches your rom and another "base" rom tab.
Old Aug 2, 2012 | 04:14 AM
  #73
211Ratsbud's Avatar
Crap ! Ok
Old Aug 2, 2012 | 04:34 AM
  #74
el.guerrero's Avatar
anyone know if is ok to tune psi based boost on a evo 9 with a 3 bar gm boost sensor? (setup properly)
if my egr is removed and blocked i have to setup also the map sensor section in ecuflash on tehpra v7 rom?(running maf not sd)
Old Aug 2, 2012 | 07:50 AM
  #75
07EvoIX's Avatar
here are the scalings you will need for the gm 3 bar
Code:
<scaling name="BoostErrorPsi GM3barMAP" units="psi" toexpr="(x-128)/(8*5.728)" frexpr="x*8*5.728+128" format="%.1f" min="-2.8" max="2.8" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="PSIa16 GM3barMAP" units="PSIa" toexpr="x/(5.728*2)" frexpr="x*(2*5.728)" format="%.1f" min="0" max="29" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="PSIa8 GM3barMAP" units="PSIa" toexpr="x/(5.728*2)" frexpr="x*(2*5.728)" format="%.1f" min="0" max="30" inc="0.1" storagetype="uint8" endian="big"/>
cheers
