TephraXMOD V1
Old Jun 23, 2010 | 11:12 PM
  #121
Djstorm100's Avatar
what does the fuel temp senor do besides the obivious? whats the purpose of the senor.
Old Jun 23, 2010 | 11:13 PM
  #122
Djstorm100's Avatar
Originally Posted by tephra
yeh you can run 2 tunes without reflashing
basically you get copies of all the important tables (Fuel/Timing/Boost) and you set up your "Alternate" tune in the "alternate maps"
switching method depends on what you choose - but most people will either use CruiseControl or TPS - see post #1 for more information
gotcha I havent messed with the software bc of lack of having a cable...can you use use any OBD II to USB cable?
Old Jun 23, 2010 | 11:21 PM
  #123
tephra's Avatar
it goes into the algorithm for EVAP - so basically the ECU decides when to vent the fuel tank into the intake manifold...
I did some quick measurements of stock cars and picked a "middle of the road" value to replace the FT sensor with.
It *shouldn't* cause any problems.
Only matters on Altmap Master=4 obviously
Old Jun 26, 2010 | 10:46 AM
  #124
EvoXCR's Avatar
Would like to give this a test... any updates to use it on 53040007 ?
Old Jun 27, 2010 | 01:39 AM
  #125
tephra's Avatar
I've uploaded 53040010
Which should suit all 2008/2009 EDM/AUDM GSR's
Old Jun 27, 2010 | 04:18 AM
  #126
therocket's Avatar
Tephra, maybe next winter I'll have to come to Australia (for job reasons).
If so, I will add one week of "stage @ Tephra's"!!
Old Jun 27, 2010 | 07:07 PM
  #127
tephra's Avatar
I have uploaded 2008 USDM MR - 52690122.
It's been pretty well tested, but not as much as the other roms - so early adopters please be a bit more cautious
Old Jun 29, 2010 | 05:18 PM
  #128
storm_trooper's Avatar
So in the usdm 08 gsr version, in the XML it wants to inherit xxxx80022, didn't have that XML at the time of download so I just changed it to inherit 0015 which is what my stock rom
Inherits.
My question is, is that going to brick my ecu if I flash it to the car. All the definitions were there and had the correct values. Just wanted input from you guys before I try to flash it to my car.
Old Jun 29, 2010 | 05:30 PM
  #129
tephra's Avatar
yeh you can do that - or you can download the missing xml's from post #1
Old Jun 29, 2010 | 05:34 PM
  #130
Okay just checking yeah I downloaded it anyway. But i didn't want to have to go back and try to reverse what I did if I didn't have too !! Thanks again tephra !!
Old Jun 30, 2010 | 03:12 AM
  #131
phughe03's Avatar
Hello tephra,
You will have to bear with me on this one as I am still educating myself on all of this. I have a 2010 GSR with rom id 53040013. Have you seen this .xml ? Is it possible to create ?
Regards
Pete
Old Jun 30, 2010 | 06:03 AM
  #132
Bob_tm's Avatar
53040013 - Wow maybe new upgrade for 2008
Could you upload the rom to a filesharing server?
Old Jun 30, 2010 | 06:11 AM
  #133
Golden's Avatar
I have definitions for 53040007 - 09. I can look at it if you want. I'll pm you my email address.
Old Jun 30, 2010 | 07:54 AM
  #134
tephra's Avatar
nah its different again...
different to 53040010 as well..
i have a basic xml - but it needs a lot..
Old Jun 30, 2010 | 04:36 PM
  #135
EvoXCR's Avatar
Thank you very much!!! Working great!!!
PayPal sent (jharrington@xxxxxx)
Great Mod!!!!
