Hard to start with ID1000's on 93
Old Jul 5, 2010 | 03:00 PM
xRoguex's Avatar
Originally Posted by Fast_Freddie
It is something that doesn't jive with those injectors and evos... and it isn't everyone either... I have no problems anymore... one day the problem just vanished and hasn't reappeared...
since all those tables are in greek to me and english to you -- could you tell me if they are all "as good as can be" for 93?
aside from that.. ill just deal with it haha.
Old Jul 5, 2010 | 04:04 PM
mullen's Avatar
man thats wierd, and wtf no love for the USN?
yes fast freddie i know its a department of the navy im just giving will a hard time
Last edited by mullen; Jul 5, 2010 at 05:27 PM. Reason: trying to keep this on topic
Old Jul 5, 2010 | 05:11 PM
Fast_Freddie's Avatar
Veteran: Navy
All but one of those tables on my car are still the stock settings, the small window on the bottom right (Startup injector...) that has 432 listed is the injectors 14v latency, just change to match your new injector 14v latency value, which is 984.
Don't you know that USMC is part of the Department of Navy...
Old Jul 5, 2010 | 05:49 PM
xRoguex's Avatar
Up until recently the USMC's paychecks said "dept of navy" on them.
Only recently did it get changed to say it was from the DOD.
And ok - ill change that .. thanks freddie!
Old Jul 5, 2010 | 05:52 PM
JohnBradley's Avatar
Bump the 9V latency (or you have it at 10v) a few thou....like 1.66 to 2.10
Old Jul 7, 2010 | 03:45 AM
tscompusa2's Avatar
should this 432 to whatever is at 14v be done on e85 as well?
Old Jul 7, 2010 | 10:09 AM
Veteran: Navy
I use map switching with E85, so it is set to whatever the 14v latency setting is on 93.
Old Aug 21, 2011 | 09:07 AM
wreckleford's Avatar
Just as a data point, I did a car yesterday with the ID1000cc injectors and didn't have any noticeable hard starting issues with them on 90 Octane fuel.
I used Travman's scaling and latency values with a slight decrease at 14v to get the trims a little better and changed no other injector related tables. The car was a AUDM 9 using the factory 88580014 ROM.
Old Apr 22, 2012 | 10:32 PM
23r0k001's Avatar
no screen shots? Im dying here. Seems like I have issues hot and cold start issues on 88590715 USDM Evo 9. Will do the TRAVMAN and give it a whirl. 93 octane NYC gas(may not be really 93 in some cases). I crank and crank past 5-7 times each time to test and still nothing.
Also moved battery to the trunk if that makes any difference. Only time my car seems to start successfully is when I apply change to the INITIAL CRANKING IP.. bottom 2 values. I can change from 0-1-2-3 and as long as its a newly saved value within the ROM it starts. So for example If I already have 1.0 set at the bottom two 2 values, in order to start successfully I need to change it to anything BUT 1 and it will start.
I also will try some "startup values" which originally work on a SD converted Evo given to me by JohnBradley. Will give it a shot regardless and report back the results. If anyone wants to test who is using SD, here they are:
Latency-
3.576
2.52
2.304
1.104
0.816
0.504
0.384
Scaling-
790
BTW thanks for your time on it JOHNNY!
Right now I have the values from rawkus which is the alternate ID1000 value seen in the SUBMERGE post.
So if anyone is having this same issue or knows what I have to change to at least startup successfully on ONE out of the TWO conditions(Hot or cold), without the need to attach the laptop every time I would greatly appreciated.
OH and as far as how the ID1000 feel; their great coming from stock 9 injector.
Old Apr 23, 2012 | 06:43 AM
23r0k001's Avatar
My 88590715 ROM does not contain these tables. Can you provide your .xml to copy and input into mine? None of the lower row and including the INJ startup I do not see.
Old Apr 30, 2012 | 02:00 PM
23r0k001's Avatar
So any updated on this injector scaling value and/or ways to get the table visible on 8859...?
mr.k
Jul 26, 2017 02:36 PM
211Ratsbud
Dec 24, 2016 10:09 AM
jdmdc2r01
For Sale - Cars For Sale
Jan 29, 2016 03:23 AM
Appauldd
Sep 21, 2015 08:39 AM
snooopy83
Jun 4, 2010 12:02 PM
