Help with map on new car.
Old Aug 1, 2010 | 09:02 AM
evoplaytime's Avatar
im running the tephra v7 and it works good. the only issue i am running into now is i hit a "brick" wall at around 230 load. i checked all the cuts and everything is above that but it bucks and kicks in that load area. no knock or even weird afr's. ill email the rom and log if anyone has any ideas. thank you
Old Aug 1, 2010 | 06:58 PM
adcgn45's Avatar
wait so on a stock rom ,1 is disable lean spool?and 0 is enable it but on a tephra rom its the opposite?
Old Aug 1, 2010 | 09:15 PM
thats how it looks. i wonder if that is wrong?
Old Aug 2, 2010 | 09:06 AM
adcgn45's Avatar
yea id say thats wrong. because i just went and looked at my stock rom and i have a 1 not a zero and im sure mitsubishi didnt have lean spool disabled.
Old Aug 2, 2010 | 09:27 AM
the only other thing i can think of is that its running out of fuel pump. im sure what pump is in it, it might be stock. i logged injector info and got 14ms pulse widths at 40% duty cycle.
Old Aug 2, 2010 | 11:07 AM
adcgn45's Avatar
only 40 percent? wow what injectors are you running? thats really low
Old Aug 2, 2010 | 11:18 AM
rc 740's set at 640. i can email you the rom and a log if you would like to make sure i did everything right. 40% and 14ms is when i hit the wall. im sure when i get up in the higher boost it works the injectors more but i dont push it because i want to fix this issue before any harm is done to the motor. i know at 40% and 14ms im getting a afr of 12.5 ish now in the map it should be lower than that so im back to wondering what the stock fuel pump will handle and if maybe they put the stock pump back in when they sold the car. i know they changed out the turbo kit and charge piping and it looks as if it had a whole fuel system in the truck judging by the wholes and the brackets.
Last edited by evoplaytime; Aug 2, 2010 at 11:31 AM. Reason: to complete a thought
Old Aug 2, 2010 | 11:34 AM
adcgn45 so on that note. is the tephra mod wrong and this could be caused by lean spool even though in the rom i have it as disabled? but with a stock rom that would be enabled?
Old Aug 2, 2010 | 12:02 PM
adcgn45's Avatar
what sort of boost are you running? a stock pump will pump stock injectors safely to about 22-23 psi .if i were you id take the time to pop the back seat and have look at that pump. if its black its stock. change it and put the walbro in
Old Aug 2, 2010 | 12:10 PM
stock boost levels with a 16g and 750's. ill have to pull the seat and look. it isnt loud though.
Old Aug 2, 2010 | 01:05 PM
adcgn45's Avatar
they arent loud they sound like stock in evos
Old Aug 2, 2010 | 01:29 PM
alright ill dig into it tonite. should i change the leanspool and see what that does? incase they got the description wrong in the tephra mod?
Old Aug 2, 2010 | 03:04 PM
Boosted Tuning's Avatar
Originally Posted by Appauldd
+1 on the boost cut. Raise the boost limit.
+1 on the injector scaling/latency adjustment. Your mid fuel trim is a little high.
The boost enhancement tables were never properly labeled. The values in that table are well below the point of boost. Don't worry about them.
The fuel cut table is set right for the load that you are hitting. It allows for a small margin of safety. I would leave it alone.
As for idle, as stated above you could add a couple degrees of timing in the idle regions. It will most likely tame the lope a little. A value around 11 should suffice. Make the low octane and the high octane timing tables the same in the idle area.....helps make idle more stable.
Before making changes to the idle tables...try just raising the timing as I just stated. If the car is still loping hard, then raise the desired idle rpm a little as stated above.
The tune itself is, as stated above, done pretty well. There is a few little things here and there that could be cleaned up, but it won't really solve your issue.
I would just disable Lean Spool via Periphery FBA bit 0. Change it to =1. Your condition should greatly improve.
Once you get the car to make consistent pulls (as I am certain you are not getting the same thing in every pull because of lean spool) then you can post up a log of a pull from 2500 out to redline. We can then tweek from there.
Hope this helps.
Paul
Paul, its "0" to disable lean spool, not "1". This applies to stock ROMs or Tephra ROMs.
See above.
Old Aug 2, 2010 | 07:15 PM
Appauldd's Avatar
Jay.....You are right.....my bad. Every dog has his day.
Sorry for the confusion.
Old Aug 5, 2010 | 11:40 AM
just an update, im waiting on a new fuel pump
nj1266
Jan 25, 2026 01:43 AM
domyz
Jul 27, 2022 11:54 AM
butte
Nov 12, 2015 04:23 PM
scheides
Mar 6, 2014 08:09 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
