EcuFlash 1.42 Problems
Old Aug 13, 2010 | 06:35 PM
jasnm21's Avatar
Well I have emailed tactrix about this issue with no response. I have a 1.3u cable with the latest EvoScan software and drivers but the cable doesn't connect to EcuFlash 1.42. It connects to 1.34 just fine but I can't do tephra v7 with 1.34.
Has anyone else had this problem and if so how did you fix it?
Thanks
Old Aug 13, 2010 | 07:30 PM
philr8's Avatar
Thanks
is your cable a genuine tactrix or a limitless (evoscan) cable?
Old Aug 13, 2010 | 08:14 PM
jasnm21's Avatar
limitless...
Old Aug 13, 2010 | 08:19 PM
philr8's Avatar
limitless...
thats your problem then, some of his cables dont have the licence from tactrix, so you cant use the newer versions of Ecuflash
Old Aug 13, 2010 | 08:23 PM
tweaker41's Avatar
If this is the case, It would be the only answer that I haven't seen that would be the answer as to why my cable doesn't work with EcuFlash 1.42. I've tried everything else.
jasnm21's Avatar
So there is no fix for this?
Old Aug 13, 2010 | 08:29 PM
tweaker41's Avatar
I'd like to know the same, I got so frustrated with it I just bought an Open Port 2.0 from Tactrix hoping that works.
Old Aug 13, 2010 | 08:32 PM
jasnm21's Avatar
The 2.0 will work, I just don't want to buy it if I don't need to.
Old Sep 1, 2010 | 11:20 AM
VGergo's Avatar
what was happened with ecuflash 1.42.2595 ? After closed and open it got a lot of grey tables like in the picture.. The rom is the original v7. Try to reinstall ecuflash but no succes. Will these tables working ?
In the options show invalid tables and show tables beyond user level is not X, but if do it nothing is change.
Cbr1000love
Jan 28, 2016 04:02 PM
sebas-chan
Sep 1, 2015 06:33 PM
ziad
Apr 4, 2011 09:04 PM
fas-n-furyus
Jul 29, 2009 12:07 PM
GTijoejoe
Apr 12, 2009 04:23 PM
