Which v5.10 for Jdm evo 8
Hi Guys,
Which ralliart rom with tephra v5.10 is out there for the 2003 JDM evo 8 6 speed. I cannot find anything on it on the forums except for, Evo 7 Ralliart Rom (Tephra V5.10) 90550001 (is that compatible??)
Also What do i need to do to the rom to be able to get it to work.
Thanks
Dale
Thanks
Dale
Thanks Phil,
I will use that one then, do I add the text file info to the evo7base xml? or to the 96260009xml? not sure what to do with them.
I will give this a go and hopefully work it out. Also is the boost setting the same for a 3 port as the v7 or is the forum post that explains how to set the boost on 5.10?
maximusnz
Sep 9, 2013 09:23 AM
