Help, moved to 96260009 and problems
Old Sep 14, 2010 | 04:04 PM
jdmevo123's Avatar
Hi guys,
I moved to 96260009 Tephra V5.10 last night, I know have the following problems.
Car starts and drives fine, but i keep throwing P0135 Oxgen Sensor Heater circuit Cel.
I am running this on a JDM 2003 evo 8 (EGR has been deleted).
Is there anyway of telling if I need a new sensor or if there is just something wrong with the rom?
Please help I have a race in 2 weeks and need to tune still.
Thanks
Dale
Old Sep 14, 2010 | 06:51 PM
jdmevo123's Avatar
wow 41 views and knowone can offer input???
Any Gurus out their that can offer some advice?
Old Sep 14, 2010 | 07:15 PM
NOMIEZVR4's Avatar
What are your fuel trims/oxygen feedback trim at? Do they at least fluctuate?
Also just to do a side my side comparison to pin point something is wrong with the rom..i would do this.
1. take the negative battery terminal off for 5 minutes
2. reconnect the terminal
3. flash your old known rom that was on the car previous
4. drive around for a good 30mins off of boost
Now if the light comes on you know that its not the ROM its the sensor but if the light doesn't come on you have a hic-up in the rom. Also see if the trims are fluctuating.
This will at least help you pin point the problem.
Old Sep 14, 2010 | 07:42 PM
jdmevo123's Avatar
Thanks, I will give that a go tonight. Im hoping its not the sensor.
Old Sep 14, 2010 | 08:23 PM
ziad's Avatar
it is easy enough to see if it is the sensor... put ur stock rom back on.
saying that i am pretty sure its the rom. as i remember someone else with a JDM8 having issues. not sure if a solution was found. if T510 is the only reason.... i am sure t510 came out for JDM8 rom.
Old Sep 14, 2010 | 08:25 PM
Evoryder's Avatar
why not flash it back to your original rom just to check. Make sure all your peripheries are correctly enabled/disabled.
Old Sep 14, 2010 | 08:38 PM
jdmevo123's Avatar
how do i get the pheriphery option in 96260009 and my stock rom so I can check they are the same? is there a bit of xml I need to put in? if so what is it?
Old Sep 14, 2010 | 09:58 PM
jdmevo123's Avatar
Does anyone know how I can get the necessary info for my XML so I can check this?
Old Sep 14, 2010 | 10:42 PM
Evoryder's Avatar
pm Tephra
Old Sep 14, 2010 | 10:48 PM
jdmevo123's Avatar
Tephra mail box is full lol.
I only need a xml that has every table shown. I can work out the rest from there.
Old Sep 15, 2010 | 03:20 AM
grayw's Avatar
The O2 sensor will still work even with a failed heater circuit. This rom has been used on many JDM and EDM VIII's without CEL errors.
leecavturbo
Feb 8, 2022 04:07 AM
kika747
Jan 30, 2017 10:06 PM
dr_jing
Apr 9, 2016 10:35 PM
nocabiwiksmx
Mar 1, 2012 12:58 AM
namwens
Oct 28, 2009 07:00 AM
