Innovate LC-1 to Evoscan
Old Sep 22, 2010 | 02:25 PM
tumtum411's Avatar
I have a problem connectiong my innovate LC-1 to evoscan,the wideband works no problem with logworks but it seem evoscan cant read it also i connect it to the right com5 because that where the wideband connected to and evoscan does log afr on com 5 even i change it still noting
Please Help Mike
Old Sep 23, 2010 | 04:51 PM
tumtum411's Avatar
anybody help bump
Old Sep 24, 2010 | 10:35 AM
justastockevo's Avatar
log the analog output with multimeter
check all connections twice
post your rom and software version info here
be persistent and you'll fix that
Old Sep 24, 2010 | 11:56 AM
erickponce's Avatar
which box do you have checked to log your afr in evoscan??
Old Sep 24, 2010 | 06:54 PM
MSP608's Avatar
Silly question, but do you have LC-1 selected under the drop down?
Old Sep 24, 2010 | 07:03 PM
wizzo 8's Avatar
You have to set evoscan to ask for the proper request
Old Sep 26, 2010 | 10:43 PM
jdm-vr4's Avatar
yes very important which box have you got checked? i had the same problem. also is evoscan set to the right port? how is the lc1 connected to your laptop? usb or com??
Old Sep 26, 2010 | 10:59 PM
tumtum411's Avatar
when my friend brings my laptop charger back,ill post screenshot he went to ocean city,md for h20 thanks a lot guys
Mike
Old Sep 27, 2010 | 04:44 AM
Eisen7's Avatar
As has been mentioned above, it's important which box you have ticked to log. LC-1 via serial cable should be 'External Wideband A/F Ratio', Request = WDB.
Old Sep 27, 2010 | 06:17 PM
wizzo 8's Avatar
I have mine requesting from 12 if that helps
Old Oct 7, 2010 | 05:33 PM
tumtum411's Avatar
going to try tonight guys ive been soo busy thanks
mike
Old Feb 20, 2013 | 01:44 PM
kaj's Avatar
kaj
back from the dead. i'm having the same issue.
i had no issue logging my old evo on my old laptop and current WB setup. a year later, i used this lap top, EcuFlash, and RomRaider to log my Subaru. AFRs logged great on RomRaider. i hook up everything with EvoScan running. i've checked my COM ports and it shows my serial/USB adapter in com 5. i set EvoScan to show my wideband at port 5. i then go down and tick Innovate LC-1 (i'm using the LC-1 with their DB gauge). so, now i have the LC-1 checked to log from port 5 (tactrix cable is on 6). nothing logs. all i get is "0". i verified the brown wire from the LC-1 is connected to the white wire form the gauge. my 3.5mm "stereo" plug is fastened to the "out" jack from the LC-1. my serial connections are zip tied together. the usb plug DOES make the windows "connect" and "disconnect" sounds when i plug/unplug it. however.. when i click the tray icon to disconnect, it only shows the tactrix cable, not the Gigaware. shouldn't they both be there? i had windows attempt to scan for driver updates.. all seem okay.
i did go to Gigaware's site and download the driver. it unzipped to my c: drive and that was it. i honestly don't know what to do from there. do i manually scan for drivers from my device manager? then find it and click?
lastly, i THINK i remember having to manually set the coms settings in device manager. does any of this ring a bell to anyone?
thanks. this sucks. LOL
Old Feb 21, 2013 | 12:35 PM
07EvoIX's Avatar
you mentoned everything else except which check box is ticked for logging AFR. is it as per mentioned above 'Wideband A/F Ratio'?
as for the drivers, did the download come with an exe file (setup/install)? if not, then you will need to go into device manager to manually install the drivers.
cheers
Old Feb 21, 2013 | 01:04 PM
kaj's Avatar
kaj
cheers
yes, the AFB (or something like that) box is checked. the drivers did not install, only unzip, so I'll have to figure out how to install them.
however! I hope I found my issue: my terminal plug is missing from the "in" line on the LC-1. i read that the wb will not output, as it is stuck waiting from input first. it cost $20 for that little plug. I hope that is the issue.
Old Feb 21, 2013 | 04:12 PM
evoredy's Avatar
The lack of 2.5mm shorting plug on the "in" is one of your problems. The serial to usb driver is your other issue (which you are fixing).
You can go to an electronics store and just buy a 2.5mm headset and cut the "earphones" off and just "twist" stripped ends that go to the plug itself together. You may even have an old cell phone earpice laying around (most are 2.5mm) that you can use. In any event, you need the shorting plug on the "in" when logging or really doing anything. Make sure to update the firmware when you get it going for best results and have fun.
