Innovate LC-1 to Evoscan
Old Feb 21, 2013 | 07:28 PM
kaj's Avatar
kaj
Originally Posted by evoredy
The lack of 2.5mm shorting plug on the "in" is one of your problems. The serial to usb driver is your other issue (which you are fixing).
You can go to an electronics store and just buy a 2.5mm headset and cut the "earphones" off and just "twist" stripped ends that go to the plug itself together. You may even have an old cell phone earpice laying around (most are 2.5mm) that you can use. In any event, you need the shorting plug on the "in" when logging or really doing anything. Make sure to update the firmware when you get it going for best results and have fun.
funny you mention the plug.. you see.. i actually happened to have one sitting around, but didn't know if shorting it out would work. i thought there were more than two wires in there. aaaaaaaaanyway, i already dropped $20 ($20!!!!) on the term plugs. dang it. anyway, too late. but i may cut one up anyway, as it won't be here until Fri.
now i gotta figure out how to find/install the drivers.
thanks! since most people post their issues with no resolutions, i'll be back to let ya'll know what happens.
Old Feb 22, 2013 | 04:10 AM
07EvoIX's Avatar
what windows you have?
basically right click my computer, click properties, click on ahrdware tab, click device manager.
any connected device that doesnt have the drivers installed will be visible in the list. right click and select update driver /9if option not available, click properties and then update driver)
cheers
Old Feb 22, 2013 | 07:34 AM
kaj's Avatar
kaj
I actually clicked "help" from my devices menu. it gave me an option to have Windows look for updates. I let it, then saw it updated Gigaware, among others. sweet. I then ghetto rigged a term plug. now works great. too bad I already ordered the $20 plug though. bleh.
Old Feb 22, 2013 | 01:25 PM
evoredy's Avatar
lol dude. have fun logging and using 50 dollar readily available WB02 sensors from 1.8 turbo volkswagens and such when you need to replace them!
Old Feb 22, 2013 | 01:45 PM
kaj's Avatar
kaj
I'm not sure what your point it's, but for sure. I stocked up on a few. a friend of mine works for VW. score! if I remember right, they're even plug n play which is a bonus. ooooh, yeeeeah.
Old Feb 22, 2013 | 01:54 PM
evoredy's Avatar
Yeah that was the point. Good luck.
Old Feb 22, 2013 | 08:00 PM
kaj's Avatar
kaj
gracias, brotha. terminated the "in" socket and it's logging normally. hopefully this info can help someone later down the line.
tumtum411
Sep 7, 2010 12:25 PM
empirepb210
90
Nov 11, 2009 11:22 PM
TouringBubble
Jun 22, 2009 11:07 AM
shuttlegoose
Jan 5, 2009 03:25 PM
fastrob691
Jan 22, 2008 07:43 AM
