Boost builds, stays flat, then surges??
Sorry to bump this up but I didn't want to start a new thread about this subject.
I just installed a MAC valve to use for boost control and am trying to get it all dialed in but at full boost 23-24 lbs the wastegate pulses (I have an EPM Open dump on the stock turbo) so I can really hear it pulsing. Any thoughts or ideas on why it is pulsing. When I was on the stock solenoid it would only pulse in 5th gear pulls and now it is in every gear.
No it can't be the clutch. I just installed an ACT XTSS clutch with prolight flywheel about 1000 miles ago. I think maybe the valve is is pulsing for some reason I'm not to sure though, it is the mac valve that came with my aquamist kit. I was thinking about replacing it with a grimmspeed boost controller but I don't think that would solve the issue.
I was wondering if having the mac- valve being plumed back into the intake is causing the Surging. have port l Routed back into the intake and port3 is the boost source and Port 2 is routed into the wastegate. lam going try leaving port1 open and see if that curse the issue
Off topic though, how do you like the clutch/flywheel setup? I just had the same clutch put in with the the Streetlite flywheel but I haven't broken it in yet.
I actually love it, this should of been one of the first things that I did when I got the car. The flywheel takes getting some use to but afterward it drives similar to the stock clutch. Mine held out for 111k before it gave out.
I was driving the car this morning and I am actually thinking that it is compressor surge and not wastegate flutter.
Cool man! I've heard a few people complain about lockout with the ACT products but not with the XTSS so hopefully I'm good there. My main concern with a new clutch was getting one that would last a looonnnggg time so it sounds like I made a good choice
Bummer on the compressor surge man. Good luck on getting that issue taken care of.
Yeah I haven't had any issues so far with it. It seems to be holding up just fine to. Im searching on the forum for possible causes on the compressor surge but I haven't found anything solid yet. I change the lower portion of the wastgate duty cycle map from 80 to 100 to see if it relieves the issue. Im getting 22-24 lbs on 70ish percent if I remember correctly. If i could get rid of the surge it would be great.
So I was wondering if I should have put a resistor inline with the bcs. I read that the stock bcs ohms out about 35 and the 3-port solenoid ohmed out at about 30-32 ohms. Would that be the cause of my fluttering?
Possibly. Have you tried putting the stock solenoid back in to see if the problem goes away? You could also try using a Grimmspeed 3 Port. Those are supposed to use the voltage as the stock solenoid.
yeah im actually thinking about ditching this solenoid for a grimmspeed. I was boosting 24lbs all day long and now this evening it is spiking to 30+, but I am letting off as soon as I see it go past 25.
arpad
179
Feb 9, 2020 03:51 AM
Zombie Killer
May 20, 2011 02:51 PM
