Cannot connect to vehicle interface!! Searched but no one has a fix!
Old Oct 20, 2010 | 05:33 AM
Tbtalon94's Avatar
^^ that didn't work either.
Any other ideas guys? I can read/write and log with Evoscan...but ECUflash just won't connect!
Old Oct 20, 2010 | 02:33 PM
charlie.tunah's Avatar
check to make sure the wire on the white plug isnt f'ed up.
Old Oct 21, 2010 | 05:25 AM
Tbtalon94's Avatar
It's all good. And if the cable was bad it wouldn't work with Evoscan. I can Read/Write ROMs with Evoscan but cannot with Ecuflash.
There's gotta be some way to make it work??
Old Oct 21, 2010 | 10:14 AM
drifterific's Avatar
I remember reading a posting on here that said the new version of EcuFlash 1.43 and EvoScan 2.7 would not work with the H8 ecu's with the 1.3 cable. I will try to find the posting and put the link here. Do you know anyone with a Tactrix 2.0 cable.
Old Oct 25, 2010 | 05:57 AM
Tbtalon94's Avatar
No i do not know anyone with a Tactrix 2.0 cable. EVOscan works PERFECTLY FINE WITH MY CABLE AND ECU.
It's ECUFLASH that doesn not work!
Old Nov 1, 2010 | 08:01 PM
kaj's Avatar
kaj
not sure if you solved your problem.. but did you set up your comm ports correctly? ECUflash and your laptop have to have the same ones selected.
Old Nov 1, 2010 | 08:02 PM
kaj's Avatar
kaj
nevermind. that's the problem i had with EvoScan. not ECUflash. LOL.
Old Nov 2, 2010 | 05:50 AM
Tbtalon94's Avatar
Haven't solved the problem, just been using EVOscan to write/read the rom and ECUflash to edit.
Old Nov 2, 2010 | 07:52 AM
kaj's Avatar
kaj
You can read/write ROMs with Evoscan?? I never knew that. I guess I've never had to try.
nvr2fst
Jul 28, 2011 01:41 PM
MonacoGP
Apr 8, 2011 02:06 PM
shawn_090
Mar 23, 2011 01:38 PM
napado
13
Mar 31, 2010 01:49 AM
Happy Madison
Jul 26, 2009 11:39 AM
