Logging Load Error and WGDC correction
Old Oct 20, 2010 | 12:05 PM
AlexEvo6's Avatar
I need some advice about logging this two...
Currently, I'm using 96530706 rom (phenem version) with gear dependant boost.
I'm not using psi based boost control, still on load based control.
Boost Error correction table is zeroed, I'm playing with main map WG duty on different gears and I'm close to what I expect for the moment.
I'm logging Load Error and WGDC correction, even if it's not used for the moment, and I have an issue.
according to mrfred thread on boost control, I've done this modifications:
Change MUT8A will read 8913. Change it to 802B
Change MUT8B will read 8D9F. Change it to 8D21
I'm reading 0 on WGDC corr, which is "normal" for me as the TBEC table is zeroed.
But I'm having a solid value (17.5) all along the log (at idle, partial, under boost).
I think maybe I'm missing something
Old Oct 25, 2010 | 09:40 AM
fostytou's Avatar
EvoM Community Team
http://www.google.com/search?sourcei...a096ba63ca8429
Change MUT8A will read 8913. Change it to 802B (again enter it as 0x....)
Change MUT8B will read 8D9F. Change it to 8D21 (again enter it as 0x....)
https://www.evolutionm.net/forums/ec...trol-mods.html
Let us know if that fixes it.
Old Oct 30, 2010 | 10:26 AM
AlexEvo6's Avatar
Fixed !
My bad, I've forgotten one of the parameters ....
In fact I messed up with the "comments" that appears with the V7 xml, they are wrong for load based boost control.
mrfred
Dec 15, 2022 11:13 AM
S15me2
Dec 8, 2016 08:22 PM
TrendSetter
Mar 14, 2016 08:26 AM
TouringBubble
Feb 15, 2016 08:59 AM
Seijuro
Mar 20, 2010 11:53 AM
