Zeitronix AFR @ 21:1 at idle
Old Oct 31, 2010 | 12:48 PM
Gocu619's Avatar
It's gonna be a while
Old Oct 31, 2010 | 12:50 PM
Gocu619's Avatar
You think I can just wrap it with heat wrap
Old Oct 31, 2010 | 03:26 PM
4xforce's Avatar
Not gonna work with the wrap. Take it to a muffler shop and have them cut it out and put a stainless pipe in it's place. Done deal.
Old Oct 31, 2010 | 04:13 PM
Gocu619's Avatar
yup that was what i was thinking as well.
Old Nov 4, 2010 | 04:37 PM
Gocu619's Avatar
So replacing the flex pipe with just a straight 3" pipe is probably not going to work due to no play at all from the engine to the exhaust. Any input?
Old Nov 4, 2010 | 10:22 PM
4xforce's Avatar
I as well as most others don't have a downpipe with a flex section. I am not a mechanic but I assume you would be fine to replace it with pipe. I have not had any issues in this regard.
Old Nov 5, 2010 | 08:13 AM
Gocu619's Avatar
4xforce
do you have spring bolts or straight bolts connecting your downpipe to the o2 housing?
Old Nov 5, 2010 | 08:48 AM
4xforce's Avatar
Currently I have a v-band coupler at the o2 housing end. Prior to that I used the stock spring bolts with the same down pipe (minus the v-band) and an EPM dump. I don't think the spring bolts even allow for much movement. As long as your exhaust fits well and is in good condition I can't see why running a piece of stainless pipe in place of the flex pipe section is gonna make much of a difference. If you are not wanting to take my word for it ask a reputable vendor or tuner on here.
Old Nov 5, 2010 | 11:21 AM
Gocu619's Avatar
thanks!
Old Nov 5, 2010 | 02:15 PM
SLO-EVO's Avatar
have you properly calibrated your wb02?
Old Nov 5, 2010 | 02:17 PM
SLO-EVO's Avatar
even with an exhaust leak, i don't think you would pull such a lean reading. i had one on my o2 housing and still had a fairly decent AFR. i am thinking that the wideband wasnt calibrated.
Old Nov 5, 2010 | 02:21 PM
Raptord's Avatar
If I'm not mistaken, there's no calibration to be done on the Zeitronix wideband...
Old Nov 5, 2010 | 04:35 PM
Gocu619's Avatar
Just replaced the pipe and the AFR is reading 15-18
Old Nov 5, 2010 | 05:24 PM
4xforce's Avatar
Sounds like mission accomplished!
Old Nov 6, 2010 | 05:46 AM
Gocu619's Avatar
Thanks!! Is that's normal around idle??
