Tuning for bigger WG
Old Dec 1, 2010 | 12:02 AM
05VIII's Avatar
I just bought a new manifold that has a tial 44mm flange on it. My current manifold uses a tial 38mm. So I will have to replace my WG to a 44mm and was just curious if a re-tune is needed since im going with a 44mm now. Would it need a re-tune even if its running the same spring? I hope I can just swap everything out and not need a re-tune.
If not, can someone give me some pointers on dialing my boost back to 30 psi? Im doing as much reading as I can before I swap manifolds and WG but there is just so much info lol.
What do you guys think?
Old Dec 1, 2010 | 12:22 AM
tscompusa2's Avatar
afr might need alittle tweaking but nothing evoscan + ecuflash + wideband cant fix in 5minutes
Old Dec 1, 2010 | 01:07 AM
05VIII's Avatar
Ok, so you think boost will not change much if any?
Who want to make a few paypal bucks to help me do any changes if needed after I do the swap?
Old Dec 1, 2010 | 01:13 AM
tscompusa2's Avatar
maybe, but i doubt timing will need fiddled with. ill pm you.
Old Dec 1, 2010 | 01:28 AM
05VIII's Avatar
can I get confirmation on this? I would really hate to go WOT after the swap and hit higher boost and blow my engine. im running e85 and its cold as **** outside...
I was tuned over the summer
Old Dec 1, 2010 | 01:34 AM
tscompusa2's Avatar
it will be determined by the spring used in the wastegate.
https://www.evolutionm.net/forums/ev...wastegate.html
according to this no difference. reason i say AFR will need adjusted is because you said you are getting a different exhaust manifold, which will require afr tuning most likely.
just make sure its the same spring rate.
Old Dec 1, 2010 | 01:56 AM
05VIII's Avatar
ok thanks. ill send you a pm after i do the swap and some logging.
Old Dec 1, 2010 | 09:28 PM
RevMoto's Avatar
You can also get the tial 38mm v-band
Old Dec 2, 2010 | 06:43 PM
05VIII's Avatar
but is the flange the same size as the 44mm? the manifold I got has a flange for 44mm. I think the flange on the 38 is a little smaller. im not 100% sure though. any one know? that would save a ton of money and I wouldnt have to worry about dialing back my boost.
nuggy00
May 14, 2017 06:57 PM
evo88dany
Oct 8, 2015 10:42 PM
Hiboost
26
Dec 30, 2009 04:28 PM
jmlsevo8
23
Aug 24, 2007 03:23 PM
AfireINSIDE
Mar 23, 2007 04:50 PM
