evoscan works fine but can't connect to ecuflash
Old Dec 4, 2010 | 01:29 PM
s.lamoureux's Avatar
I have an 06 EVO IX MR with the openport 1.3U cable. Evoscan 2.8 works fine but I can't connect at all to EcuFlash 1.42. I get a "no response to any known code" error. Do I need a different version of the program?
Old Dec 4, 2010 | 01:38 PM
xmaciek82x's Avatar
Is it cold outside? Sounds like the same issue I had.
https://www.evolutionm.net/forums/ec...-problems.html
Old Dec 4, 2010 | 01:45 PM
yeah it is pretty cold out, i'll try letting it run for a little thanks.
Old Dec 4, 2010 | 03:14 PM
ok I drove the car around and let it run for a bit and this is the new error i'm getting:
[18:10:04.769] Using interface OpenPort 1.3 Universal TX2CsVnW9dc6e4cd3932aa0ca6651b85013b28b522b076b5
[18:10:06.688] sending init sequence 1 (0001)
[18:10:07.733] got 0x05 response
[18:10:07.733] sending init sequence 2
[18:10:07.733] got 0x1B response
[18:10:07.733] sending init sequence 3
[18:10:08.123] entering bootloader
[18:10:08.123] sending kernel size (0)
[18:10:08.139] sending kernel load address (0xFFFF6000)
[18:10:08.139] error sending kernel load address
[18:10:08.154] interface close
on my defi gauge it said I was over 12 volts while trying to connect
Old Dec 5, 2010 | 09:52 AM
ahhh im about to go out and buy a ****ing red top and see if that helps...
Old Dec 5, 2010 | 02:38 PM
tried downgrading to version 1.29a stll didn't work, and now evoscan won't even work...
Tfresh
Feb 20, 2014 03:21 PM
kyoo
Feb 25, 2011 05:48 PM
jasnm21
Sep 1, 2010 11:20 AM
vboy425
Oct 9, 2009 04:40 AM
AlwaysinBoost
Sep 14, 2009 01:01 PM
