Evoscan/Ecuflash wont connect please help!!
I cant get Evoscan or Ecuflash to connect for the life of me. Ive tried older versions, charging the battery, checked continuity of the tactrix cable. The car wont start and I need to get a inspection done. It starts fine on the AEM EMS but not the stock ecu. I want to connect to the ecu and see what faults/errors it has so I can get them sorted and get the car inspected. I have searched and tried all the tips people offered and none have helped me
I will gladly paypal someone $50 if they can get it to work
I have also tried using ecu unlocked in conjunction with the programs and no luck.
I get the following errors:
Evoscan- Cant connect to ECU
Ecuflash- No response to any known code
Yes thats correct. To switch to my stock ecu which I have done last year no problems was to put factory MAF back on and plug it in and plug the factory MAP sensor in. I have done this in the past with no issues so im not sure what went wrong.
JFYI Fuse #8 blew when the wires got cut. Car will not send fuel, communicate with ecu(duh) or spark if this blows.
This post saved my life:
https://www.evolutionm.net/forums/10256532-post12.html
Bewstzalot
Jul 7, 2017 01:35 PM
