How to tune 800whp
Old Dec 23, 2010 | 03:54 AM
  #91
F0RSAKEN's Avatar
Originally Posted by LGshow19
Ive read that somewhere you posted this... Good info for sure. Just surprising it doesnt cause knock with AFRs like that and timing.
Ive noticed that to about running anything below 11-10.9... power just dips low like it hit a wall.
I doubt he'd register much knock at negative timing @ peak load unless he was running waaaaaaay lean, but that's just my uneducated guess
Old Dec 23, 2010 | 06:37 AM
  #92
3gEclipseTurbo's Avatar
Any reason you stopped at 27psi? People seem to get away with 29-31psi on pump with that turbo.
Old Dec 23, 2010 | 06:56 AM
  #93
LGshow19's Avatar
Aaron... What AFRs were you shooting for during peak load along with the negative timing?
Old Dec 23, 2010 | 09:52 AM
  #94
JohnBradley's Avatar
It was 27 at peak power, but it was 29 at peak boost. 11.9 across the board, 12.5-12.8 during spool.
Aaron
Old Dec 23, 2010 | 10:25 AM
  #95
C6C6CH3vo's Avatar
How far did timing sweet spot change with the 2.4 compared to 2.0?
Old Dec 23, 2010 | 11:04 AM
  #96
Aaron
Sense you have the timing so low at peak boost couldnt you have gone up to say 31psi spike so it would hold more psi out to peak power?
Old Dec 23, 2010 | 11:05 AM
  #97
Also what was the AFR at peak boost?
Old Dec 23, 2010 | 04:34 PM
  #98
Not at all. I would have suspected that 2mm would have been more but all the 86.5-87mm motors are the same as the 85mm ones it seems. 92 octane is limited to about 29-30psi. I am not interested in pushing it further on pumpgas. I put it back on E85 before I headed to ETS to discuss the next kit Someone should ask Michael to post his impressions of the car and antilag though. Apparently I shoot flames.
  #99
Aaron
Old Dec 24, 2010 | 07:04 AM
  #100
TJung's Avatar
I've learned a lot of important things from this topic Aaron. I am waiting for better weather in Poland to test my new setup on GT30R and I think I will need a little help :/
Please check Your email Aaron
Thanks!
Old Dec 24, 2010 | 04:43 PM
  #101
Sure thing Tomas. I checked after this post and hadnt seen it yet though. Did you send to my email (like you normally do) or the business one?
aaron
Old Dec 24, 2010 | 05:44 PM
  #102
n2oiroc's Avatar
how is that magnafuel pump plumbed? do you have a surge tank setup?
Old Dec 24, 2010 | 06:31 PM
  #103
Stock fuel top is modified with a bulkhead -8 fitting to the pump, -6 feed to the rail, Aeromotive 13909? regulator, stock return. Its wired with 8 gauge and a relay and has an aeromotive pump controller to drop voltage below 3,000r.
aaron
Old Dec 24, 2010 | 07:07 PM
  #104
n2oiroc's Avatar
aaron
the bulkhead fitting goes to a pickup tube to the bottom of the tank i imagine?
Old Dec 25, 2010 | 12:32 AM
  #105
To stock depth. I have a filter plumbed in and mounted on the firewall.
