Reading knock voltage data....?
Ok so I was curious if anyone with some experience on here could shed some light on this subject. Ive posted a log below and a graph of knocksum and knock voltage vs RPM.
How does the ECU decide when to show a "knock sum" value? Im more interested in spotting false knock. As a side note Id like to say that I dont really suspect this log to have any false knock it was just a good clean example with some light knock. I see the knock voltage begin to climb and then a 4 count is show that tapers down to 2, 1 then 0 again. The voltage does go down as well but by the time the voltage is in the same amplitude area of where there was no "knock sum" shown previously it is still showing 1-2 counts.
What about the 2 count shown right at the beginning of the log? There isnt much amplitude for the voltage there. I realize that I have only shown the window of the pull and you can see whats going on right before that 2 count but from what I recall it is pretty flat..
Any info is greatly appreciated!
Thanks,
Ethan
| RPM | TimingAdv | Load1B | KnockSum | WideBandAF | JDMMAP | InjPulseWidth | InjDutyCycle | KnockVoltage |
| 2468.75 | 19 | 92.4 | 0 | 14.4207 | 0.78413 | 6.656 | 14.04 | 0.936 |
| 2468.75 | 18 | 100.8 | 2 | 14.6412 | 0.9776 | 7.168 | 14.56 | 0.507 |
| 2375 | 17 | 102 | 0 | 15.9936 | 1.94495 | 7.168 | 14.37333333 | 0.6435 |
| 2437.5 | 17 | 102 | 0 | 15.9936 | 1.94495 | 7.168 | 15.30666667 | 0.819 |
| 2593.75 | 17 | 104.4 | 0 | 15.9936 | 2.33189 | 7.68 | 16.6 | 0.6825 |
| 2531.25 | 13 | 109.2 | 0 | 12.201 | 2.9123 | 7.936 | 16.53333333 | 0.4875 |
| 2468.75 | 11 | 111.6 | 0 | 12.201 | 2.9123 | 8.192 | 17.06666667 | 0.8385 |
| 2531.25 | 11 | 112.8 | 0 | 12.201 | 3.10577 | 8.448 | 18.48 | 0.6435 |
| 2656.25 | 11 | 115.2 | 0 | 12.201 | 3.68618 | 8.704 | 19.26666667 | 0.78 |
| 2625 | 10 | 118.8 | 0 | 12.3186 | 3.68618 | 9.216 | 19.92 | 0.624 |
| 2593.75 | 10 | 123.6 | 0 | 12.3186 | 4.26659 | 9.472 | 20.72 | 0.78 |
| 2687.5 | 10 | 124.8 | 0 | 12.3186 | 4.847 | 9.984 | 22.62 | 1.053 |
| 2718.75 | 9 | 129.6 | 0 | 12.3186 | 5.04047 | 10.496 | 23.50666667 | 0.819 |
| 2687.5 | 8 | 135.6 | 0 | 12.2598 | 6.00782 | 11.264 | 25.52 | 1.053 |
| 2750 | 7 | 141.6 | 0 | 12.2598 | 6.20129 | 12.032 | 27.88666667 | 1.1505 |
| 2781.25 | 5 | 150 | 0 | 12.2451 | 7.74905 | 12.8 | 29.66666667 | 1.131 |
| 2812.5 | 3 | 157.2 | 0 | 12.2451 | 8.13599 | 13.568 | 32.15333333 | 1.1505 |
| 2875 | 3 | 164.4 | 0 | 11.7894 | 9.29681 | 14.336 | 34.72 | 1.209 |
| 2906.25 | 2 | 174 | 0 | 11.7894 | 10.45763 | 14.848 | 35.96 | 0.9945 |
| 2937.5 | 2 | 182.4 | 0 | 11.7894 | 11.23151 | 15.36 | 38 | 1.3065 |
| 2968.75 | 2 | 188.4 | 3 | 11.5542 | 12.39233 | 16.384 | 40.96 | 1.365 |
| 3000 | 0 | 200.4 | 3 | 11.5542 | 13.94009 | 17.408 | 44.42666667 | 0.897 |
| 3062.5 | -1 | 211.2 | 4 | 11.5542 | 15.68132 | 18.688 | 48.18 | 1.1505 |
| 3125 | 0 | 222 | 3 | 11.3778 | 17.03561 | 19.456 | 51.17333333 | 1.677 |
| 3156.25 | 0 | 228 | 3 | 11.3778 | 17.61602 | 19.968 | 53.04 | 1.7355 |
| 3218.75 | 1 | 231.6 | 3 | 11.3778 | 19.16378 | 20.224 | 54.77333333 | 1.1505 |
| 3250 | 1 | 235.2 | 2 | 11.025 | 19.35725 | 20.224 | 55.82666667 | 1.7745 |
| 3312.5 | 1 | 231.6 | 2 | 11.025 | 20.51807 | 19.968 | 55.64 | 1.8525 |
| 3375 | 1 | 226.8 | 2 | 10.8192 | 20.3246 | 19.712 | 56.46666667 | 1.833 |
| 3468.75 | 2 | 225.6 | 2 | 10.8192 | 20.3246 | 19.712 | 56.98 | 1.6965 |
| 3500 | 2 | 226.8 | 2 | 10.8192 | 20.90501 | 19.712 | 58.00666667 | 1.0335 |
| 3562.5 | 2 | 226.8 | 2 | 11.0838 | 20.71154 | 19.712 | 59.54666667 | 1.9695 |
| 3625 | 3 | 225.6 | 2 | 11.0838 | 19.93766 | 19.456 | 59.78666667 | 2.1645 |
| 3718.75 | 3 | 223.2 | 2 | 11.4219 | 20.71154 | 19.712 | 61.6 | 1.6185 |
| 3750 | 3 | 225.6 | 2 | 11.4219 | 19.93766 | 19.712 | 62.62666667 | 2.262 |
| 3843.75 | 3 | 225.6 | 2 | 11.4219 | 19.55072 | 19.712 | 63.65333333 | 0.8385 |
| 3906.25 | 3 | 225.6 | 2 | 11.4807 | 20.13113 | 19.968 | 66.56 | 0.936 |
| 4031.25 | 3 | 228 | 1 | 11.4807 | 20.13113 | 19.968 | 68.12 | 0.9555 |
| 4093.75 | 3 | 228 | 1 | 11.4807 | 20.3246 | 19.968 | 68.64 | 0.663 |
| 4156.25 | 4 | 229.2 | 1 | 11.3337 | 20.51807 | 20.224 | 71.62666667 | 0.624 |
| 4250 | 4 | 231.6 | 1 | 11.3337 | 19.93766 | 20.224 | 72.15333333 | 0.6435 |
| 4312.5 | 4 | 231.6 | 1 | 11.2749 | 20.51807 | 20.48 | 74.66666667 | 0.819 |
| 4375 | 4 | 231.6 | 1 | 11.2749 | 20.3246 | 20.48 | 75.73333333 | 0.5655 |
| 4468.75 | 4 | 232.8 | 1 | 11.2896 | 21.09848 | 20.48 | 76.8 | 1.131 |
| 4531.25 | 4 | 234 | 1 | 11.2896 | 19.93766 | 20.48 | 77.86666667 | 0.702 |
| 4593.75 | 3 | 236.4 | 1 | 11.2896 | 20.51807 | 20.736 | 79.92 | 0.6825 |
| 4687.5 | 3 | 236.4 | 1 | 11.3925 | 21.09848 | 20.736 | 81 | 0.78 |
| 4718.75 | 3 | 237.6 | 1 | 11.3925 | 20.3246 | 20.992 | 83.64 | 1.716 |
| 4812.5 | 3 | 238.8 | 1 | 11.319 | 20.51807 | 21.248 | 85.76666667 | 1.1895 |
| 4875 | 4 | 240 | 0 | 11.319 | 21.29195 | 21.248 | 86.87333333 | 0.7995 |
| 4906.25 | 4 | 241.2 | 0 | 11.319 | 20.71154 | 21.248 | 87.98 | 0.858 |
| 5000 | 4 | 242.4 | 0 | 11.3043 | 21.09848 | 21.504 | 90.72 | 1.053 |
| 5062.5 | 4 | 246 | 0 | 11.3043 | 20.90501 | 21.76 | 91.8 | 0.7215 |
| 5093.75 | 3 | 248.4 | 0 | 11.2455 | 21.29195 | 22.016 | 95.17333333 | 1.4625 |
| 5187.5 | 4 | 249.6 | 0 | 11.2455 | 21.29195 | 22.016 | 96.32 | 0.8775 |
| 5250 | 4 | 250.8 | 0 | 11.1573 | 21.87236 | 22.016 | 97.46666667 | 1.6575 |
| 5343.75 | 4 | 250.8 | 0 | 11.1573 | 22.2593 | 22.016 | 98.61333333 | 0.507 |
| 5406.25 | 4 | 250.8 | 0 | 11.1573 | 22.2593 | 22.272 | 100.92 | 0.9945 |
| 5437.5 | 4 | 252 | 0 | 11.025 | 21.87236 | 22.272 | 102.08 | 1.131 |
| 5531.25 | 4 | 252 | 0 | 11.025 | 21.87236 | 22.272 | 103.24 | 1.5795 |
| 5562.5 | 4 | 253.2 | 0 | 10.8633 | 22.06583 | 22.272 | 104.4 | 0.8385 |
| 5656.25 | 4 | 252 | 0 | 10.8633 | 22.06583 | 22.016 | 104.92 | 1.0335 |
| 5750 | 4 | 250.8 | 0 | 11.0838 | 22.06583 | 22.016 | 105.4933333 | 1.872 |
| 5781.25 | 3 | 250.8 | 0 | 11.0838 | 22.45277 | 22.016 | 107.2133333 | 0.9945 |
| 5843.75 | 3 | 250.8 | 0 | 11.0838 | 22.2593 | 21.76 | 107.1 | 1.833 |
| 5906.25 | 3 | 249.6 | 0 | 11.2455 | 21.67889 | 21.76 | 108.2333333 | 1.2285 |
| 5968.75 | 3 | 249.6 | 0 | 11.2455 | 21.67889 | 21.504 | 108.08 | 1.404 |
| 6062.5 | 3 | 246 | 0 | 11.4072 | 21.67889 | 21.248 | 107.9 | 2.0085 |
| 6093.75 | 4 | 244.8 | 0 | 11.4072 | 21.48542 | 20.992 | 107.6933333 | 1.4625 |
| 6187.5 | 5 | 242.4 | 0 | 11.4366 | 21.87236 | 20.992 | 108.7866667 | 1.716 |
| 6218.75 | 5 | 241.2 | 0 | 11.4366 | 21.29195 | 20.736 | 108.54 | 1.131 |
| 6281.25 | 6 | 238.8 | 0 | 11.4366 | 21.87236 | 20.48 | 107.7333333 | 1.3455 |
| 6343.75 | 6 | 237.6 | 0 | 11.4219 | 21.87236 | 20.224 | 107.44 | 1.8135 |
| 6375 | 6 | 236.4 | 0 | 11.4219 | 21.48542 | 20.224 | 109.5466667 | 1.794 |
| 6531.25 | 8 | 231.6 | 0 | 11.5248 | 20.90501 | 19.712 | 107.8 | 1.833 |
| 6562.5 | 8 | 230.4 | 0 | 11.5248 | 21.29195 | 19.712 | 107.8 | 2.1255 |
| 6562.5 | 8 | 229.2 | 0 | 11.5248 | 20.3246 | 19.712 | 108.8266667 | 1.677 |
| 6656.25 | 9 | 228 | 0 | 11.4513 | 20.90501 | 19.712 | 109.8533333 | 2.0475 |
| 6718.75 | 9 | 225.6 | 0 | 11.4513 | 20.3246 | 19.456 | 108.9333333 | 1.7355 |
| 6750 | 9 | 223.2 | 0 | 11.5248 | 19.74419 | 19.2 | 108.5 | 1.755 |
Thanks,
Ethan
I would say it's a combination of factors. Rpm /load/maf sensor/knock voltage/af...etc .the ecu will use all factors to determine when a knock sum is needed. There is code that allows you to adjust the knock sensor sensitivity.
Regarding your pull I noticed you have negative timing around 3k???
Regarding the negative timing. Im in the middle of a new tune and the timing map has just been rescaled and super conservative to get some knock control and straighten out my fuel. So the timing value in those load cells is 0 or 1 and since the ECU is seeing knock its retarding it down further..Its in the works....
Weird that my TPS values didnt copy over...hmm
Knock is frequency based, the voltage is amplitude.
On our motors its technically 6700hz and the secondary harmonic is checked to see if it "rings" and then decides its real. I have heard from the DSM disassemblers that its 6200 and 12400 (double amplitude) that they are checking but I dont have anyway to confirm that.
All that being said, I have seen 36 counts of knock register .7v and I have seen 3.94v be knock free. Depending on what fuel you are on (91 I would say its real) I would think you are seeing phantom based on knock V vs boost vs timing.
aaron
aaron
aaron
aaron
thank you for that explaination... do you think i'm having the same thing based on the logs I've posted in my thread?
^- I saw your thread and took a read. Your knock count is much higher then mine and from what I thought was sporadic. Like just shows up with 15-25 counts and then goes away. Mine is transient which i thought was more like a real knock situation? I know that my AFR's are ok and timing is obviously low. But I do have some unsmooth parts in my map. Hopefully that is the reason for the knock as it seems to happen in the same area most of the time. I really dont want to get into playing with the knock filters and multipliers etc..
mchristian
Aug 18, 2011 10:47 AM
rraulston
28
Sep 21, 2005 09:55 AM
