Speed Density Closed Loop Operation Questions
There is a decent number of corrections that can take place in that AFR select sub. I think several of them are disabled though.
Also, I think the ECU can also select a couple different AFR values outside of that main AFR value. They may be for fault conditions though. It's one of those parts of code where it looks for an offset to a RAM variable and IDA looses the path at that point.
the next step to closed loop is changing the AFR swing for catalyst efficiency. Since we no longer have cats in our cars... our closed loop operation should operate much more stable than it does. I asked MrFred to see if he can find out how to reduce the AFR swing and the frequency during cruise.
With LC1 analog out I manage a 15.0-16.0 window at cruise, switching rate depends on RPM. This is with instant sample feedback using flash v1.00.
The ECU NBO2 rear signal (pin 76) is actually hooked up to the front O2 sensor keeping ECU happy thinking it's hooked up to a fired up cat.
Havent figured idle yet
Its pretty straightforward to lookup the RAM address manually. The array address can be found either at the start of the subroutine or traced back through higher subroutines. Once you've got the array address just add the offset, and go there.
scheides
Oct 22, 2021 08:59 AM
ecktt
May 8, 2017 06:18 PM
