E85 Timing number on Stock IX Turbo
Old Jan 21, 2011 | 04:23 PM
TheBoz's Avatar
So I have a pretty much bone stock evo with a 9 turbo. I am running e85, and I am trying to get a good idea of what kind of peek torque timing numbers people have along with peek RPM timing numbers.
Currently I am at
1* = Peek Torque
16* = Peek RPM
The car does feel sluggish when approaching peek torque. According to VDR is it making about 250tq@3600 and holding until redline. So I knew there is more in it. ALso this is only at 21psi. But I am pretty sure the car shoudl be in the 300+tq range even at 21psi.
Old Jan 21, 2011 | 04:26 PM
gkania's Avatar
Currently I am at
1* = Peek Torque
16* = Peek RPM
Why use such a low boost level with a fuel with such a high anti knock index?
The peak tq is low for such low boost. 1* at 28-30psi sounds about right though. For 21psi, you might consider 4-6*. Good Luck.
Old Jan 21, 2011 | 04:40 PM
Jim in Tucson's Avatar
I took a peek at some old data logs...
I was at
6* = Peak Torque
24* = Peak RPM
IX turbo on an VIII at 19/21 psi making VDR 324trq/377whp.
Keep bumping up your timing little by little and keep checking your VDR.
Old Jan 22, 2011 | 08:43 AM
TheBoz's Avatar
Just working on getting the tune to work before I start turning up the boost. A good foundation is the best way to start for me.
I also need to switch to big maps, I am still working from the oem map, which maxes out about 260 load. So once I have a good fuel and timing map, I will make the switch. Figured I would dial it in first before making the cut.
Coxor
Sep 22, 2020 01:13 PM
campetersen
Nov 22, 2016 05:02 PM
EvilDSM97
E85 / Ethanol
12
Nov 4, 2015 04:49 PM
blkmkIII
Pacific Northwest
11
Feb 23, 2012 10:17 PM
TheBoz
Nov 20, 2011 11:32 AM
