Speed Density 2.0 (3D VE Tables, Baro)
Old Jul 23, 2013, 05:53 PM
  #751
211Ratsbud's Avatar
Originally Posted by 90zcrex
You don't really need to use excel. You just log your volumetric efficiency while still on maf Rom. And then filll out the VE table in you SD rom with the values you logged. You can set it up so that you can read kpa vs rpm in evoscan logviewer and then just transfer over to your sd ve table.
This is exactly what I started doing today.
My ve from my already tuned by target afr set up was very close in some areas, transitional pressures, and off by 10 or so at 240 kpa. That's just a reflections of the already tuned sd ve table being based of ideal afrs vs my maf rom having typical 10. Xx to achieve 11.xx.
I'm gonna unhook my wga from the flapper. This method has tremendously leaped and bounded over the log and lookup map adjust ve flash method
Old Jul 24, 2013, 02:20 AM
  #752
MercenaryX2's Avatar
Thanks for that. Reason I ask is cause I just had a headache of a time creating an SD table from scratch for a buddy of mine and he was getting rather impatient with me. Partially his fault cause he installed the SD sensors and deleted the MAF then sold it before we even flashed it to an SD rom... I'll remember this though.
Old Jul 24, 2013, 05:14 AM
  #753
211Ratsbud's Avatar
I'm comin up with some odd ve calculations . I'm only using wot data, there's a big difference between 220 kpa and 240 kpa
Can anyone share a 3d view done this way?
Old Jul 24, 2013, 07:32 AM
  #754
90zcrex's Avatar
What kind of difference are you getting? What rpm? I see around 102-105 VE in that area at around 3700-3900 rpm. I actually didn't even use Evoscan while making my VE map. It's pretty easy to just look at a couple datalogs and get an idea of what it should be in certain areas. Now that I've fixed the 1:1 issue I'm reading almost dead on with my maf tune at WOT. I have a couple small areas to add a little fuel withe VE but overall it was pretty damn easy. Almost too easy lol.
Old Jul 24, 2013, 09:31 AM
  #755
211Ratsbud's Avatar
220 kpa sees 120% tapering to 114%
240 kpa sees 111 tapering to 103
I took all of my wot logs, combined them in to one log and used map tracer to display that log. Used map as my x axis too
Now that I've worked out the kinks so I can brake load every thing like hell lol
Old Jul 25, 2013, 10:03 PM
  #756
Jack_of_Trades's Avatar
It's not uncommon to see VE begin to taper down as load increases. This is generally due to the engines actual VE being limited by back pressure in the system. That does seem like a drastic jump from 220 to 240 though.
-Jamie
Old Jul 25, 2013, 11:55 PM
  #757
el.guerrero's Avatar
is properly to adjust VE to get afr map closer to afr you log? or is really wrong?
Old Jul 26, 2013, 04:20 AM
  #758
211Ratsbud's Avatar
-Jamie
Thx, I'm workin in my logging technique still maybe ill get that one sorted over a few more. 240 kpa is wastegate pressure so I mainly have increasing tps logs across those 220 cells. Segway to..
Is it important to use increasing tps only or ca. Steady state tps data be used aswell?
Old Jul 29, 2013, 02:51 PM
  #759
211Ratsbud's Avatar
I unhooked my waste gate actuator and got my ve for 100-110 kpa, I don't believe that would effect ve. Does anyone have any thoughts there?
Old Jul 29, 2013, 04:58 PM
  #760
domyz's Avatar
No effect to VE (in my thinking)....
what I can say is that I found something that messes the VE calcs logging:
A synapse BOV can be either open or shut at the same load and rpm (i.e 80 load/3000RPM) depending on TPS behavior (movement/speed/up or down).
Like you said, it's important to log only stable/raising tps and no decel at all while doing this method.
Old Jul 30, 2013, 08:44 AM
  #761
Big Bald's Avatar
I have a stupid question. Speed Density uses the 3D VE table exclusively even if running open loop full time? I thought i read somewhere that above 90% throttle is switches to the fuel map. I searched for the answer on here but did not find anything to confirm that.
Old Jul 30, 2013, 09:32 AM
  #762
evo8426's Avatar
It uses the VE map 100% of the time.
Old Jul 30, 2013, 06:01 PM
  #763
EvocentriK's Avatar
OK couple of mega noob questions.
I have a JDM 8 and I'm running 96534706 (3d). I read the 9653 MAF rom being based on EDM was never designed for use with a MAP sensor. Now I'm obviously running one (GM3bar) and I have it connected to pin 92 of my 3 plug ECU. I log this input from MUT38. However for SD rom the rom needs to know what boost is, but I have no code to set to 1. scale the GM3bar and 2. tell the rom what address to look at for the MAP sensor input. I'm assuming this rom was written for USDM cars with a MAP sensor and the address for this input coded in accordingly. What do I need to do since I run this rom on a JDM 3 plug?
All I have are these settings for Max VE etc.
What do I set them to and do I need additional code to set GM3bar scaling/address so the rom can use it. Mrfreds thread has all but 9653 code.
Old Jul 30, 2013, 10:46 PM
  #764
211Ratsbud's Avatar
Right click on the map kpa table and be sure that bathe scaling for map sensor is set to your 3 bar.
8858 that I use also did not come with a map sensor.! Map:kpa table is the one you're concerned with though.
Old Jul 31, 2013, 12:58 AM
  #765
EvocentriK's Avatar
Yep I have scaled both to GM3bar. But how does it know what the output of the MAP sensor is if you never tell it what address to read it from?
When changing from stock to JDM MAP sensor the Mid VE Max voltage/min voltage etc need to be changed. I'd like to know what to do with them for a GM 3 bar too.
Quick Reply: Speed Density 2.0 (3D VE Tables, Baro)
