Zeitronix Map Sensor Speed Density
Old Feb 11, 2011 | 01:20 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
I was wondering if anyone has done the speed density setup using the map sensor that you can buy for the zeitronix AFR. I have searched and can't find anything, if anyone has any info i would appreciate it TY
Old Feb 11, 2011 | 01:36 PM
RoadSpike's Avatar
I did it with their 5 bar sensor.
You'll probably want to contact them via email for an adapter which is like 20 bucks if i remember it. Secondly you'll probably want to use the map sensor adapter for an AEM unit which uses the same thread type as the zeitronix sensor. This will be like another 30-40 bucks.
At that point it should work.
Old Feb 11, 2011 | 08:16 PM
whats this adapter for?
Old Feb 11, 2011 | 10:01 PM
RoadSpike's Avatar
You'll want the adapter so you can literally plug it into the stock wiring harness spot. The zeitronix round 3 pin doesn't fit in the square 3 pin stock plug .
Of course i'm suggesting the sensor literally would be on the manifold putting in some line somewhere is doable but not advised. You want instantaneous pressure inputs not delays.
Old Feb 11, 2011 | 10:23 PM
lmao OOOOO ok that makes more sense now, i didn't think about it really i was just figuring that i would need to make a few splices but adapter are nicer. Also did u scale the map sensor yourself or did you use the aem? thanks
Old Feb 11, 2011 | 10:53 PM
RoadSpike's Avatar
I created those scalings you know :P
I called them AEM because the sensors from zeitronix and AEM are indentical. Plus i figured people would have been more likely to have an AEM one than a zeitronix one.
Old Feb 14, 2011 | 12:09 PM
well i got in touch with zeitronix and ordered the harness adapter, THANK YOU!!!
evillancer06
Jan 10, 2016 02:56 PM
elkazX
Feb 27, 2015 08:21 AM
Silver-IXse
May 8, 2013 07:53 AM
ch53avitech
Apr 21, 2012 03:37 PM
RSMike
23
May 14, 2011 06:08 PM
