Ecu Flash noob question
Old Feb 13, 2011 | 10:06 PM
wtmodnar's Avatar
Hello All,
I just wanted to get some input from you guru's out there. I am a noob at ECU flashing, I have never done it and I am really interested in learning. I have been reading some of the basics in reflashing. My real question is the equipment and suggestions from your experience would be the easiest route to get started. I was thinking Tactrix 2.0 (I heard some people had problems, but I cant seem to beat people to the punch when finding the 1.3), lc-1 wideband, Ecu Flash, and Evo Scan.
Any input would be greatly appreciated. I just want to get the the right materials the first go around and not waste any unnecessary funds. I am really ambitious and just want to started data logging and see what I could do. Thanks ahead of time.
Old Feb 14, 2011 | 02:24 AM
vd's Avatar
vd
Dream team in my opinion is:
1) Evoscan
2) Ecuflash
3) Openport 2.0
4) Zeitronix Zt-2 (wired directly into ECU)
5) Omnipower 4-bar MAP-sensor
6) Grimmspeed 3-port BCS
7) small and light laptop with good battery
8) Tephra v7 ROM from the very beginning
Obviously it is not the best composition in terms of cost-minimization. However, it is great in terms of usability and possibilities you have with this setup.
It is just MHO, so take it FWIW.
Old Feb 14, 2011 | 12:52 PM
EvoRuss's Avatar
Definately go with what vd said. I use the AEM uego and don't like it too much. I have seen alot of the innovative lc-1 vice the zeitronix. All in all a good list.
Old Feb 14, 2011 | 01:47 PM
Raptord's Avatar
1) Evoscan
2) Ecuflash
3) Openport 2.0
100% agree. I was lucky enough to have all that already installed in the car when I bought it, minus the 3-port BCS, which I installed myself in 10 minutes. You will not regret going with a setup similar to this.
Old Feb 14, 2011 | 11:44 PM
wtmodnar's Avatar
thanks for input, its not a matter of the pricing really, just dont want to buy things I dont need. Hope to start logging and flashing soon! thanks again
Old Feb 15, 2011 | 12:11 AM
vd's Avatar
vd
You're perfectly right approaching the process with a lot of logging first. Just note that 3-port BCS require minor tuning together with installation (zero-out the WGDC and target boost/load tables for the very beginning, your car will run with less boost after that, but it is safe and you will dial in the boost settings later when you get the idea of what's going on). Flashing Tephra v7 ROM at the very beginning is also not that much complicated and gives you more room for tuning, just follow the instructions in the threads where setting of the v7 is described (mainly check that the values are identical in all the maps in your old ROM and the v7 you're flashing in and substitute your values for immobilizer).
All these things are covered very good in topics here by really knowledgeable people, so you will have the process running smoothly after doing some reading.
PS also don't forget to save your current ROM in few safe places so that you always have the maps that are working good with you car
Old Feb 16, 2011 | 10:26 AM
acidtonic's Avatar
Can you substitute the ZT-3 which only does AFR? Does anyone use the extra features of the ZT-2?
I figured if i'm logging the ZT-3 in evoscan, along with a MAP sensor, why would I use the ZT-2?
Old Feb 16, 2011 | 10:29 AM
Raptord's Avatar
ZT-2 has the advantage of the LCD for seeing everything in one place; AFR, EGT (optional), boost (optional), and you can connect a pressure/temp sensor to the USER2 input to have oil pressure, oil temp, water temp, etc.
Old Feb 16, 2011 | 10:49 AM
acidtonic's Avatar
But isnt the LCD another expensive add on? Those other sensors that need purchased also bump up the price even more. I feel as though a basic wideband with a boost gauge fits my needs.
SlavaGC8
Sep 10, 2013 02:48 PM
MarioTME
Apr 27, 2009 12:18 PM
hokiruu
Sep 29, 2007 11:32 AM
thatsMR2u
Jun 8, 2006 07:12 AM
evolve_
May 5, 2006 11:35 AM
