MAP Sensor Install
Old Feb 15, 2011 | 02:06 PM
widge's Avatar
MAP Sensor Install
Hey Guys i own a ADM Evo 8 GSR which doesnt come factory with a MAP sensor,
Is there instructions on how to install and wire a MAP sensor so i can use it for PSI based Boost Control and SD later on?
Thanks guys, ive searched cant find anything
Old Feb 15, 2011 | 02:17 PM
RoadSpike's Avatar
run 3 wires to it from the ecu mount however you please. In your case if the manifold isn't tapped with a MDP port that just sealed off you may be better off using a non OEM style MAP sensor like GM or alternatively tapping the manifold and using a AEM/zeitronix style sensor as you need to splice into the cpu anyways.
Power +5volts pin 81
sensor input pin 73
sensor ground pin 92
http://www.evomoto.com/skin1/images/evo_harness.gif
Old Feb 15, 2011 | 02:30 PM
widge's Avatar
You sir are a true champion
Old Feb 15, 2011 | 03:30 PM
Tonba's Avatar
I have a 5BAR Haltech MAP sensor. Am I able to hard wire this and log off the standard ECU?
For SD, do we need a AIT sensor? While my intake is off, should I install one into the intake??
Cheers
Old Feb 15, 2011 | 03:43 PM
RoadSpike's Avatar
Cheers
Is it a 5 volt sensor? If so yes and if not no..
I prefer honestly to have the IAT in the IC pipe as its easier for one to do and doesn't suffer heat soak. And you need some kind of heat sensor be it using the fuel temp or something else.
Old Feb 15, 2011 | 06:08 PM
Tonba's Avatar
The Haltech sensor uses a 0-5V signal which is linear.
What formula should I modify in ECU flash considering it is is a 5BAR?
Old Feb 15, 2011 | 06:48 PM
widge's Avatar
Tonba,
do you have the MAP sensor section in your XML?
I dont and im running Tephra v7 7653 so if someone has the data to put into the XML for MAP Sensor would be awesome too
evoRS06's Avatar
Can u post a pick of ur intake manifold cause I haven't heard of any of the ct9a chasis not having a map sensor, just curious
Old Feb 15, 2011 | 07:30 PM
widge's Avatar
The ADM Evo8 GSR most definately does not it has the port for it but nothing on it and its not drilled out,
So basically now what im asking is once i have the MAP sensor installed with Tephra V7 9653 ROM i want to use PSI based boost Control so doesnt there need to be a MAP Sensor scaling table or something like that in the rom which it does not, or is that not required?
Thanks
Old Feb 15, 2011 | 07:55 PM
evoRS06's Avatar
Wow, u always learn something. What's ur rom?
Old Feb 15, 2011 | 08:09 PM
widge's Avatar
I worked out my ROM issue all i had to do is select the PSI base tables and change the scaling to what ever MAP sensor i have installed,
So i have this link to a Omni 4 Bar Map sensor but it also says GM in the add too
http://cgi.ebay.com/ebaymotors/OMNI-...Q5fAccessories
Is that a Omni 4 Bar Map sensor?
Old Feb 15, 2011 | 09:29 PM
evoRS06's Avatar
Well I don't know what that is to exactly, but it's not the omni 4 bar that I or any other evo ive seen use, I mean it could work but u should just get one from a reliable dealer, cause all the scallings are on the forums.
Old Feb 15, 2011 | 10:22 PM
Tonba's Avatar
Get a Haltech 4bar one. Easy as!
Old Feb 17, 2011 | 06:21 PM
Tonba's Avatar
Hmmm, I wonder if they are the correct PIN's for a JDM Evo 8 GSR?? Anyone?
Old Feb 17, 2011 | 06:28 PM
widge's Avatar
I would say they would be i cant see Mitsubishi changing the Pin-Outs per Region,
We will also need some banana pins Tonba as it will just be a blank spot on the ECU output
