Built motor in car LEAN now !
Old Feb 18, 2011 | 09:57 PM
wizzo 8's Avatar
A little off topic but may help. Can you remove the honeycomb part of the maf and still have good drivabilty if tuned?
Old Feb 18, 2011 | 10:05 PM
RoadSpike's Avatar
yeah mellon does that tune or so i'm told.
Old Feb 19, 2011 | 01:37 AM
Mellon Racing's Avatar
correct...I've been removing the honeycomb since the mid 90's on my TT Stealth and carried that trick over to EVOm when I bought my EVO 8
it does not add horsepower but it does keep your turbo from eating it. I don't typically tell customers to do this mod unless they are going for over 30psi and getting tuned.
Old Feb 19, 2011 | 06:05 AM
wizzo 8's Avatar
I guess ill have to remove it then since I'm already at 35psi.
Old Feb 19, 2011 | 09:54 AM
5LEEPERISAH23I's Avatar
I think I found the problem. My silcone intake was leaking underneath so u couldnt see it but could feel it.. Took it off n just put it back on , the intake is now firmer and it is on right. Just need to try it out n see .. Makes sense that would be the problem tho .. Unmetered air sneaking in causeing it to run lean
UPDATED! : That was not the problem ! WTF still leaning out... i saw it off a bit and thought that was deff it....
So checked Boost leaks NON
Checked MAF Honey comb stuff still in tact
Checked FPR hose still on
Any other idea's?!
Old Feb 19, 2011 | 03:18 PM
wizzo 8's Avatar
That would definitely cause it.
Old Feb 21, 2011 | 09:25 AM
that wasnt the problem! whaaaa
Old Feb 21, 2011 | 10:03 AM
wizzo 8's Avatar
Hows your fuel pressure? Maybe your fuel pump is on its way out
Old Feb 21, 2011 | 12:35 PM
mt057's Avatar
Have you changed your injector scaling since changing the displacement? Has the car been tuned for 15psi? Are you still having boost control issues?
Old Feb 21, 2011 | 01:25 PM
I am having boost control issues
and yea i have changed the injector scalings
Old Feb 21, 2011 | 03:53 PM
what are sytomps of it going on its way out?
going lean at WOT?
wouldnt it not start sometimes and stuff like that?
Old Feb 21, 2011 | 05:26 PM
wizzo 8's Avatar
going lean at WOT?
Yes it would go lean at wot. Not on Mitsubishi's but on BMWs I have seen fuel pumps work fine but at full throttle fall on its face. If you check the fuel pressure it drops at wot.
Old Feb 21, 2011 | 05:29 PM
ok friday im going to benchmark the injectors, replace the fuel pump filter , and see if that does anything
after that put in my stock fuel pump just to test if it still goes lean or not
Old Feb 21, 2011 | 05:35 PM
wizzo 8's Avatar
Unfortunately there is no fitting on the fuel rail to hook up a fuel pressure gauge to test it. You could add a tee into the supply line to the fuel rail if you really want to test fuel pressure. Obviously you would also a fuel pressure gauge.
Old Feb 21, 2011 | 05:49 PM
ok didnt know there was no way to hook it up, but i have a friend that has a gadge to test it
