Help: EcuFlash can't read ECU
Old Mar 30, 2011 | 09:49 AM
napado's Avatar
use ecu unlocker.
Old Mar 31, 2011 | 06:46 AM
03Silver's Avatar
I tried didn't work
Old Mar 31, 2011 | 11:12 AM
burgers22's Avatar
Check you don't have a problem with the second power plug. The wires on these can become disconnected on the old 1.3 cables, though I've not seen a problem on the OP2
Old Mar 19, 2015 | 07:25 AM
memphis69's Avatar
Originally Posted by 03Silver
It says "an error occured. see the log for details"
in the log it says:
"Sending int sequence 1 (0001)
Sending int sequence 1 (0003)
Sending int sequence 1 (FFFF)
Sending int sequence 1 (F0F0
no response to any known code"
have the same issue with 1.3U on my EVO IX. 2.0 works well. this 1.3U works well on friend's EVO VIII.
Old Mar 19, 2015 | 02:20 PM
evo8426's Avatar
Start the engine and warm it up a little bit, it will charge the battery enough to be able to write to the ECU.
Old Mar 19, 2015 | 04:49 PM
memphis69's Avatar
hm, interesting. i have mini battery and car stay some time.
thank you!
sba
Mar 30, 2025 10:44 AM
XSilverJ
Aug 10, 2016 03:56 PM
stunt2
Sep 28, 2015 03:15 PM
ecktt
Apr 19, 2015 02:20 PM
eastxcelerate
Mar 5, 2010 09:06 PM
