MAP Sensor and 94170715 Rom
Old Feb 21, 2013 | 05:38 AM
EvoIXPilot's Avatar
I don't see 94170715 Rom listed as one of the Roms I can on both the JDM Sensor and Omni Sensor instructions. I noticed that there are subverisons of the 94170715, one specifically for the Omni, but not the JDM. What do I need to do? Do use the 94170715 for the Omni and copy all my existing maps/settings over (not sure if that's safe or possible)? Or do I just copy the xml info in there???
Old Feb 21, 2013 | 11:12 AM
evo8426's Avatar
After reading through the threads and comparing the ROMs I have come to the conclusion to use these settings for the JDM MAP Sensor:
MAP Test 1: Mid VE High Voltage -- Change from 4.61 volts to 4.80 volts.
MAP Test 1: Mid VE Low Voltage -- Change from 0.10 volts to 0.06 volts.
MAP Test 2: Low VE Max Voltage -- Leave at 4.22 volts.
MAP Test 3: High VE Voltage -- Change from 1.8 volts to 0.51 volts.
"EGR MAP Offset #1" should read:
750 97
1000 86
1250 75
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
And "EGR MAP Offset #2" should read:
750 97
1000 86
1250 84
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
Change *both* tables to:
750 84
1000 84
1250 73
1500 65
1750 60
2000 55
2500 48
3000 43
3500 23
Change the "EGR Pressure Diff" from 0.12 to 0.04.
These settings for OMNI 4 Bar Sensor:
EGR MAP Offset #1
750 97
1000 86
1250 75
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
EGR MAP Offset #2
750 97
1000 86
1250 84
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
Old Feb 21, 2013 | 02:57 PM
EvoIXPilot's Avatar
Thank you!!!
Old Mar 2, 2013 | 07:40 AM
EvoIXPilot's Avatar
OK, I was trying to make the changes and had some additional questions:
On my ROM there is also MAP Test 2: Low VE Max Voltage. Am I supposed to change that to something or leave it alone (4.22 is what's on there)
Also MAP TEST 3: High VE Min Voltage-- it won't let me put in .5. Everytime I put in .5 or .50, it defaults to .51. Will this be ok?
Thanks!
MAP Test 1: Mid VE High Voltage Test -- Change from 4.61 volts to 4.80 volts.
MAP Test 1: Mid VE Low Voltage Test -- Change from 0.10 volts to 0.06 volts.
MAP Test 3: High VE Voltage Test -- Change from 1.8 volts to 0.5 volts.
Old Mar 2, 2013 | 08:10 AM
evo8426's Avatar
Leave it at 4.22 for Test 2 and .51 will be fine for Test 3
Old Mar 19, 2015 | 09:30 PM
bsbllfit7's Avatar
With these exact settings put in, I am getting low vacuum readings at idle. I havent taken it out for a drive yet but it is showing -6-7 psi at idle when my gauge is showing closer to 14 or so. Any thoughts?
turbotaloon95
Aug 9, 2016 07:51 AM
okevolutionVIII
Jul 29, 2016 01:13 AM
DemiSlayer
Oct 17, 2014 05:25 PM
shadow1
Jun 18, 2011 02:56 PM
