Problems getting ECU controlled boost to work.
Old Jul 16, 2016 | 04:12 PM
okevolutionVIII's Avatar
After having problems getting it work countless times and switching back to a MBC, I'm trying it again. I've went through several threads each time and still can't get what I want out of it.
I have an '03 Evo VIII using an Omni 4-Bar and a GM 3 port EBCS on a Tephra V7 94170715 ROM.
No matter where I set the baseline WGDC, BDE PSI, and Boost Adder, it seems to completely run off the "WGDC=100% under the load" setting where I tested it at 100 and 150 load where it stays at 100% and dives straight to 0% at that load through the whole pull. Even with the WDGC and PSI table zeroed out on the Alternate map, it does the same thing and same boost. Boost increases with each gear at roughly 4psi per gear, 28psi in 1st to 40psi in 4th with 0% WGDC.
I can upload a pic of my table settings later but it has to be something else seeing what I've already tried.
Old Jul 21, 2016 | 03:54 PM
TrendSetter's Avatar
40 psi at 0% wgdc sounds like your solenoid is hooked up wrong.
Old Jul 22, 2016 | 04:03 AM
Raceghost's Avatar
And wouldn't he it Boost cut Load? Doesn't that also drop the WGDC down?
Old Jul 22, 2016 | 07:47 AM
lancerrally45's Avatar
More than likely it is hooked up backwards.
Old Jul 24, 2016 | 09:56 PM
Hooked up exactly like this. When blowing through port C, air comes out of port A.
Old Jul 25, 2016 | 10:01 AM
Can you wire it backwards? I forget, its been a bit.
Old Jul 25, 2016 | 05:11 PM
you cant wire them backward, solenoids dont care about polarity.
i still say its a hardware issue. if the pcm was commanding 0% wgdc and you were making 40psi then something is stuck.
Old Jul 25, 2016 | 05:58 PM
I'll try to find my old EGR solenoid and use it as a 3 port, the connectors are the same.
Old Jul 29, 2016 | 01:13 AM
Raceghost's Avatar
Check the other thread bud, from a tuning perspective. You know the one.
PsychDr. HN$
Jan 15, 2013 12:25 PM
ChadS
Jul 26, 2012 02:23 PM
razorlab
Apr 2, 2008 09:04 AM
JDMevoBOOST
19
May 9, 2007 08:18 PM
DynoFlash
12
Nov 14, 2006 02:44 PM
