05mr cant read rom
You should still be able to save the rom. Open it again and use the method I described in this post.
https://www.evolutionm.net/forums/7813559-post14.html
Also i went thru the whole method of finishing after that and now when i open file the car info shows up under rom data and it says flash method id mitsukernel whats this? internal id is 96940013 inherit from 96940011
Make sure these xml's are in your rom meta data folder.
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
thats the default location unless you changed your settings.
How do i do so? i havent changed anything but the user level to developer. And i cant get it to do anything for me!! anyone that is willing to help via text or over the phone please pm me
All it shows when i open the file now is the Rom info tab and under that i have make model etc internal id 96940013. Flash method: mitsukernal, Memory model SH7062,
Inherits:96940011.
Sorry for all the questions but im new to the evo tuning thing ive used dsp's only when i tuned previously.
Inherits:96940011.
Inherits:96940011.
Inherits:96940011.
So i started from step 1 again and i went the route the link in a few post above stated and i go the rom id using the evo7 base as a inheret 96940013 now how do i get it to read? And i cannot find the rometa data folder to look through the xml's
I posted where it is in post #19 you know..
ok i got the file to show up i went to evo and it has all the numbers in it and i added the 96940013 and it already had the 96940011 and evo7base in it. AND.....................................
I FINALLY FREAKIN GOT IT THANKS SO MUCH MAN!!!!
I'm not trying to be a pr!ck, but if you are having trouble finding something this simple, then I suggest that before you try and tune the car, you get someone local to you to show you the basics of opening saving and backing up your ROM files. Again, not trying to insult you, but that is a pretty simple action and should be easy enough for someone with reasonable PC skills.
