Need -19º stock ecu evo VIII 2004 USDM
Old Mar 28, 2011 | 06:39 AM
Spizz's Avatar
Hi I need help, and I tried everything, tephra 5.1, 7, timing retard, and not get my timing down to -10 º I need someone to help me. My USDM Evo VIII is a 2004, stock ecu ide 9417008.
I can pay dollars or euros, to transfer to one to help me I live in Spain
Help please. If you can not do this let me know too please.
Old Mar 28, 2011 | 06:40 AM
Spizz's Avatar
need -19º only
Old Mar 28, 2011 | 06:58 AM
Jedi_Gill's Avatar
FCOTM Winner
I might have one, but what's a 19 degree Ecu mean?
Old Mar 28, 2011 | 07:25 AM
todd6027's Avatar
he means he cant get his timing to go down to -10
Old Mar 28, 2011 | 07:26 AM
Raptord's Avatar
He wants to be able to retard timing to -19°
Old Mar 28, 2011 | 02:24 PM
Spizz's Avatar
Old Mar 28, 2011 | 07:09 PM
Boosted Tuning's Avatar
Look for the table "Ignition retard limit". Its set for -10 stock.
Old Mar 28, 2011 | 07:20 PM
JohnBradley's Avatar
Doesnt work. Tried already on the VIII, there must be a missing table somewhere.
aaron
Old Mar 28, 2011 | 07:22 PM
RazorLab's Avatar
aaron
You need to also change the value in the table at 0x173e for 7/8 and 0x133e for 9.
Setting the value to:
220 allows -15°
237 allows -18°
255 allows -22°
Also from mrfred awhile back:
Originally Posted by mrfred
I've been sniffing around the subroutine that sets the ignition retard limit, and it appears that in the newer ROMs, there are two ignition retard limit tables that are used for two different operating conditions. Not sure yet on what conditions these are, but here are the two tables for the 8859XX15 and the 9653XX06. They may both need to be set more neg for ignition to retard further under all conditions. Note that the max possible neg value is about -28 deg. Should be easy for people running newer JDM, EDM, and ADM ROMs to find the additional table by comparing the offset between the two addresses.
8859XX15:
<scaling name="IgnTimingECUa" units="deg" toexpr="61-x*90/256" frexpr="(61-x)*256/90" format="%.1f" min="-30" max="50" inc="1" storagetype="uint16" endian="big"/>
<table name="Ignition Retard Limit #1" category="Timing" address="205e" type="1D" level="1" scaling="IgnTimingECUa"/>
<table name="Ignition Retard Limit #2" category="Timing" address="133e" type="1D" level="1" scaling="IgnTimingECUa"/>
9653XX06:
<table name="Ignition Retard Limit #1" category="Timing" address="2438" type="1D" level="1" scaling="IgnTimingECUa"/>
<table name="Ignition Retard Limit #2" category="Timing" address="173e" type="1D" level="1" scaling="IgnTimingECUa"/>
88570008-88570014, 88580013-88580015, 88840016, 88900006
<table name="Ignition Retard Limit #1" category="Timing" address="2038" type="1D" level="1" scaling="IgnTimingECUa"/>
9417XXXX has only one ignition retard limit table:
Old Mar 28, 2011 | 09:45 PM
donner's Avatar
220 allows -15°
237 allows -18°
255 allows -22°
I have tested mrfreds addresses with 9653 and best I got was -10. With 9 (8858) I can get -20.
Old Mar 28, 2011 | 11:54 PM
Also verified that the 173e in 94170015 doesnt go past -10. I added the following addresses and settings as I would in the IX-
0x173f
0x4300 (decel ignition cut limit)
Then I altered the EGR timing table and nothing. Unless I am having a super blonde moment, there is something else we dont have for the USDM stuff. It works in the IXs, havent been able to get any VIIIs to work.
Old Mar 29, 2011 | 01:47 AM
Spizz's Avatar
There are some VIII USDM to -15 º or -19 º?????? with stock ecu. or is it a legend??
Old Mar 29, 2011 | 04:59 AM
Benja's Avatar
Can't get my JDM 7 to go past -10 either.
This is whats defined in my 9055 XML.
table name="Ignition Retard Max Degrees - dec" category="Timing" address="173e" type="1D" scaling="Retarduint16"/>
<table name="Ignition Retard Max Degrees - hex" category="Timing" address="173f" type="1D" scaling="RetardHex8"/>
Old Feb 5, 2012 | 07:07 AM
EvocentriK's Avatar
...wrong thread.....cannot delete post.........
vaqusis
56
Sep 29, 2017 08:35 AM
211Ratsbud
Dec 24, 2016 10:09 AM
TouringBubble
Sep 22, 2008 06:28 AM
TouringBubble
Oct 15, 2007 04:05 PM
Evo11V
33
Mar 2, 2004 06:33 PM
