SST MR/SE 1st gear TPS limiter FOUND!
IDKwhat happened, I changed TPS scaling to: x*100/255 from x*200/255 and get the usual 86 max. weird coincidence?? cause I never changed it to 200 in th first place.
anyhow, TPS limit is adjusted higher and results are very good
Thanks again to all involved with this
Weird.
Yeah the front page is wrong. I may have told Bryan wrong when I first found them.
2009 EDM SST 54070007 and 2009 USDM Ralliart 53600010
- The y-axis RPM addresses should be 625f0 instead of 6258e.
And yes they share the RPM scaling with the Boost tables... Passive / Reactive and others.
I personally like to manage 1st gear torque with the boost tables. It's much less abrupt and offers more resolution.
You can try setting this table to 100% to remove the TPS limits and then limit your first gear torque with the gear-based boost tables.
This way your also not trying to cram a bunch of boost through 50% throttle plate which I would assume causes a bit of back pressure on the turbo.
Of course, everyone has their different ways.
Compared to how the car left the line before, it feels like a rocketship, I may have to limit them more again based on temps the car will see during launches at the One Lap event.
Mischief managed on my 2010 SE. I am not yet sure if it made a huge difference but nothing went wrong during the test drive. Really I won't know until I hit some of my typical left-turn pull-out intersections while not *thinking* about the change I just made. I'll know right away if I'm worried about making it across or not.
I also tested out launch control for the first time. Not sure how much that is effected by the TPS CAP but I would assume it is ... I was underwhelmed by the launch in launch control [shrug] Might also be my low-gear WGDC boost settings but I haven't played with them much beyond using values from GUNZO
for reference I changed the non-100 drive values to 90 68.2 64.3 66 74.2 81.8 ... those represent the mid-point between the old value and 100.
Has anyone tested all 100's?
If COBB ever releases this ill tell you what it does at the strip with it set at 100%, or if someone wants to do it for me i live in NY. I have 1/4 mile data from this year and last to see the 60ft improvment.
Perhaps I'm missing something but I don't really understand the excitement around this. Stock the throttle plate limiter is in effect limiting boost/torque which is just another method of boost control w/o using the tables. That way you aren't crippling boost in whatever other gears you are running your low range boost maps. It really shouldn't make that much of a difference if you have them tuned properly!?!?!?! In fact, if you just move it to 100%...I'd check/log (beta ECUFlash Standalone logger logs much faster now!) how much boost you are seeing in 1st gear!
verkion
verkion
verkion
verkion
You're right, I can't possibly see why people are excited about this.
verkion
verkion
Before the throttle closed to 40% at WOT in 1st gear and you had NO CONTROL over it.
Now you have control over it. So you can do what you please with it. Still want less throttle / boost? You can have it. What full boost / throttle? You can have it.
Before you had no choice.
and larger turbo Evo MR's couldnt launch at all with the limiter.
Look a SSP's Mr there is a video of it launching... there is nothign until J would shift to 2nd them it took off like a rocket.
Look at my vids on youtube, same thing 1st gear lame duck, click 2nd gear and you can hear the diffrence in the car.
