Any definitive fix for RPM hang?
Old May 12, 2011 | 09:24 AM
btmboards's Avatar
I have done a decent amount of searching and all I can seem to find is speculations and random things that maybe seems to work once.
I am running a basicly completly stock tune with tephra V7 installed with a couple of rom patches. I have an intake, 3" straight pipe, wideband, about to install mbc and the rest is suspention.
I have rearly bad thottle hang when I run my car hard or in the heat. It is anoying but not an issue if commuting but do to my bike being down, I am taking my car to Palamar Mtn this weekend (7.5 miles of no straight lines running up the side of a mountain) I want to run it hard but really need my engine braking and dont want to run it into a corner have my car stuck at full rev and throw myself through a gaurd rail. I have be working on building my car for this type of driving so I need to fix this regardless of what I do this weekend, But would love to try it out for the first time.
Please let me know any help is greatly appretiated.
Old May 12, 2011 | 07:04 PM
evoredy's Avatar
Reconnect the TB coolant lines and replace the ISCV/re-adjust idle properly.
Worked like a charm on my buddy's 05 MR with the meanest throttle hang in the world. Someone did the TB coolant bypass "mod" and his newer style plunger/spring type ISCV went bad.
Check if your car is "modded." Also, your ISCV has gone bad if you've done the whole ECU troubleshooting route.
Good luck man.
Old May 13, 2011 | 08:38 AM
btmboards's Avatar
It isn't bypassed I fought the car completely stock. But I will look into all that tonight and tomorrow. Thanks a lot
Old May 13, 2011 | 02:29 PM
Boosted Tuning's Avatar
Email me your ROM and Ill help you out.
Old May 14, 2011 | 08:49 AM
btmboards's Avatar
Just sent you an email, thank you for all you help. let me know if you need anything else
Old Dec 10, 2011 | 06:55 AM
playmajohn's Avatar
did you ever get this issue resolved? I have a throttle hang as well it was after I had a clutch put in.
Could it be the clutch causing the rpm's to hang?
Old Dec 10, 2011 | 03:12 PM
Is your EVO 8 an 05?? The 03-04 didnt have the rev hang issue.
Old Feb 2, 2012 | 12:43 PM
newbieEVO8's Avatar
I've started to notice this issue also on my IX.
Old Feb 20, 2012 | 02:46 PM
MR_Evo_Rob's Avatar
Bump. I have an 06 MR and mine has started to hang right at 2,500rpm fairly often during short drives. Any info would be helpful.
Old Feb 20, 2012 | 06:19 PM
BumpNasty's Avatar
So, the fix to this issue is to simply have the car properly tuned?
Old Feb 20, 2012 | 06:31 PM
vmrevo9's Avatar
Veteran: Air Force
so how bad is bypassing the coolant lines? most of the aftermarket TB's ive seen do not have connections for the coolant lines.
my IX has always had "throttle hang/wandering idle" even before the big mods made their way onto the car. is it definitely a tuning issue?
Old Feb 20, 2012 | 08:23 PM
Yes. There is some tables in the 05-06 ROM that need to be changed to get rid of the throttle hang.
Old Feb 21, 2012 | 01:28 PM
MR_Evo_Rob's Avatar
Blah, I guess its time for another tune then.
Old Feb 21, 2012 | 01:33 PM
Email me your ROM and Ill make the changes for ya.
Old Feb 21, 2012 | 03:34 PM
Pirana's Avatar
Mmm also happens to mine in a AEM.
