leaning out and stalling at idle
Old Jul 25, 2011 | 11:12 PM
stunt2's Avatar
when coiming on stop and putting car in neutral, afr leans out at 16-17, rpm drops and car almost stalls. recovers to normal 14.7 and 900 rpm very slowly. does it quite often but not always.
my question is, can it be something rom related (96530706) or mostly the mechanical issue ? knackered o2, bad idle stepper motor, boost leak or something ?
havent had this issue, only began 2-3 days ago
Old Jul 28, 2011 | 09:25 PM
utripin's Avatar
bad fuel pump??
Fuel pump? How old is your pump? I just went through this scenario.
Old Jul 28, 2011 | 10:52 PM
stunt2's Avatar
nearly 2 years old, wallbro
don't think it's faulty. pumps strong at higher rpms and doesn't lean out
Old Jul 28, 2011 | 11:00 PM
Frank120's Avatar
Who tuned it?
Old Jul 29, 2011 | 12:54 AM
stunt2's Avatar
myself
Old Jul 29, 2011 | 01:34 AM
06RedRalli's Avatar
Vacuum leak?
Old Jul 30, 2011 | 12:55 PM
GregM's Avatar
Mine leans out sometimes when coming to idle. Its as if the ecu is too slow in making adjustments.
Old Nov 28, 2011 | 02:42 PM
ddb's Avatar
ddb
oups!
Old Nov 28, 2011 | 02:43 PM
ddb's Avatar
ddb
Did you found the issue?
Old Nov 29, 2011 | 12:19 AM
stunt2's Avatar
no, problem still remains
Old Nov 29, 2011 | 02:34 PM
ddb's Avatar
ddb
I have the same problem, it started last week. I increased the desired idle rpm during drive and neutral and it helped a little but there is still something weird about that.
Did you check your IAC in the throttle body?
Are you running in psi-based boost control?
Old Nov 29, 2011 | 02:48 PM
Revo15's Avatar
i had this same exact problem..i cleaned out my egr valve, my throttle body and changed my throttle body shaft seals and works wayy better now...my AFR stays at 15.2 at idle!!! i know i know very stable..lol
Old Nov 29, 2011 | 02:50 PM
Revo15's Avatar
also are u bov to atmosphere or rec?i think you also have a boost leak too so you might wanna do a boost leak test.
Old Nov 29, 2011 | 03:14 PM
usnevo8's Avatar
this happened to me. my idle is set at 1500 because it wanted to stall but that didnt help. i'm vta now with an hks.. im pretty sure it isnt leaking but ill try the vaccum test and ill try cleaning the throttle body and see how that works
Old Nov 29, 2011 | 03:19 PM
Revo15's Avatar
Most of our evos 8 & 9's have the weak throttle body shaft seals from factory...thats why it leaks under boost pressure Stm has them for 35 bucks i think..i bought mine and believe me a biggg difference!
