General non-information about factory ALS
Old Apr 2, 2014 | 08:34 PM
  #796
tunermt's Avatar
wow that is a nice piece but DANG not a cheap piece to machine.,very interesting though!
Old Apr 3, 2014 | 01:10 AM
  #797
VGergo's Avatar
Originally Posted by EvocentriK
This car here is group N evo and sounds pretty badass on decel and is running ALS on idle, and it's only running factory ALS hardware. It seems this is enough for ALS, but the ECU just can't control it/add enough fuel for long enough/allow enough neg timing.
all gr.n cars going with pre-opened throttle that is why needed the fuel / ignition cutted idle . instead of the engine would run 4000rpm. the new pre-opened tb is the 0 zero tp for the ecu ( have to calibrate ) and over that with 3-4% the ecu release the cutting to leave the car running . The pre-opened TB needed because the extra air help turbo to spin.. with the idle control valve open you can have bigger or less antilag .
without TP - RPM axis ignition retard table never will have antilag..also the sounds is quite different as you can heard in the video than a simple ignition retard, it has TP-RPM igntion cutting table too.
the sas system is not used on the GR-N cars..just the rules say have to be on..
the wrc runing "sas type" als without popping or like this..they try create a turbo jet with good succes from the turbo.. but it cause a lot of heat.
First needed to upgrade the ecu rom, this is the biggest issue against the real als.
Old Apr 3, 2014 | 10:44 AM
  #798
211Ratsbud's Avatar
For less than 100 dollars I can build a flange that does mimic that concept definitely not as pretty . The manifold I cannot build easily.
250 for my design flange in 304 ..
Old Apr 8, 2014 | 03:07 PM
  #799
VGergo's Avatar
at all i do not want to kill the topic with my post, but here we definitly need a software solution / patch... may Mr.Fred or other professional can check the possibilities. I can help what exactly needed.. ( tables, configuration, compensation.. )
Old Apr 8, 2014 | 04:43 PM
  #800
211Ratsbud's Avatar
-I jumped to vi-pec. And hooked the sas up to that: my results were wild turbo surge at low rpm and no surging at upper rpm. More bypass volume is needed to turn surging into turbo speed and give more effect up top.
I'm working on using a denso Subaru maf to measure air flow when sas is active on decel and sas is not active on decel.
I'm hoping to use this like a poor mans turbo speed sensor and get an idea if I'm making turbo speed
Old Apr 9, 2014 | 09:06 AM
  #801
foxbat's Avatar
I don't think you're killing the topic, I totally agree in regard to the software solution. I think Ratsbud tried contacting some of the developers to no avail.
Old Apr 9, 2014 | 05:17 PM
  #802
211Ratsbud's Avatar
I mean the road is vast here let's look at the questions that plague us:
Secondary air anti lag or throttle bypass? If sas is everyone going to be on board with possible hardware changes that will need to be made? If bypass what method of providing air bypass to the intake will we develop with ? Does the majority of users under stand that sas does not show up on a standard boost gauge? Does the end user have a solid way to calibrate turbo speed or measured airflow?
We can't spend money that most of us really don't have to pay a developer code what we don't know we need for coding.
I'm in a vipec so that I could understand what it took to make it work. But I already have the carriage ahead of the horse with no turbo speed measure, I'm going to buy a maf housing tomorrow for the Subaru maf I have. Poor mans turbo speed indicator.
We need to calculate secondary air flow rate some how. Does anyone know how to build a device that can calculate flow rate with analog gauges?
I want to test the flow rate of the sas system all together.
Can I use a stop watch with a known volume and pressure and time how long it takes to drain from say 80 psi to 30?
Old Apr 9, 2014 | 05:34 PM
  #803
211Ratsbud's Avatar
From my millions of google searching and a lot of wrc lancer you tube videos plus others, like wtc you'll notice that the fresh air systems ( true fresh air) do not pop and bang nearly as much and appear to generate turbo speed by a better balance of timing and fuel. " quieter " is evidently less hazardous.
I'll continue to try the factory sas especially once I read airflow, with various amounts of timing and fuel vs using a traditional throttle bypass ignition retard amount.
Old Apr 9, 2014 | 06:34 PM
  #804
211Ratsbud's Avatar
Ordered the maf housing a few mins ago.
Old Jun 17, 2014 | 01:51 PM
  #805
211Ratsbud's Avatar
New stainless 316l 90* bends are done, 3/4"! This will fit the tial flange nicely and promises to be my best incarnation to date!
Old Jul 27, 2014 | 04:12 AM
  #806
tunermt's Avatar
Throttle bypass antilag system on my Vr4 (AEM ems)
Old Jul 27, 2014 | 11:34 AM
  #807
211Ratsbud's Avatar
Video Link: http://www.youtube.com/watch?v=f577XUQgTcY
As an alternate route I've been looking at throttle bypass.
Good work making the AEM do that, idle does sound aggressive.
Old Aug 14, 2014 | 04:07 AM
  #808
tunermt's Avatar
I'm still slacking on posting up the video of the secondary air injection ALS set up on my S13 but that system is a good bit more aggressive.
Old Aug 14, 2014 | 11:05 AM
  #809
211Ratsbud's Avatar
Slacker!
Old Aug 14, 2014 | 03:40 PM
  #810
211Ratsbud's Avatar
Originally Posted by 211ratsbud
Slacker!
I have been testing a setting in which my vipec uses a single solenoid to control a boost only source to my lower bov port and under set conditions applies this secondary source to hold the valve open. Increasing shaft speed by means of boost leak ..I'm trying to get the maf logging feature set up so I can do a With and without test. Some hang ups in maf logging so far
Likely the reason my thrust washer is spent as well
