Scaling 1450's help
Old Sep 12, 2011 | 07:03 AM
PlanoEvo's Avatar
Scaling 1450's help
Running FIC Blue Max 1450's with a Map 2.3 10.5:1 motor cams ported everything blah blah blah.Here are my results can someone chime in what you would change if any to make the results better?
Scaling 860
4.69 2.880
7.03 2.520
9.38 1.728
11.72 1.368
14.06 1.248
16.41 0.984
18.68 0.840
low trim -5.586
mid trim 2.834
Old Sep 12, 2011 | 01:51 PM
Spec-Ops1's Avatar
pump gas or E85?
Old Sep 12, 2011 | 01:57 PM
PlanoEvo's Avatar
Originally Posted by freddie@spec-ops
pump gas or e85?
e85
Old Sep 12, 2011 | 05:43 PM
Spec-Ops1's Avatar
I am going to be honest with you... I wouldn't change anything as the trims are rather close... trying to get the trims perfect will drive you crazy!
Old Sep 13, 2011 | 06:34 AM
PlanoEvo's Avatar
Running FIC Blue Max 1450's with a Map 2.3 10.5:1 motor cams ported everything blah blah blah.Here are my results which are about as close as I can get it
Scaling 943
4.69 2.784
7.03 2.448
9.38 1.608
11.72 1.344
14.06 1.244
16.41 0.984
18.68 0.816
low trim 1.66
mid trim 1.85
Old Sep 13, 2011 | 06:35 AM
PlanoEvo's Avatar
Already a little crazy so had to try to get closer and I did
Old Sep 13, 2011 | 08:34 AM
chetrickerman's Avatar
Veteran: Army
Very nice. You should add it to the injector scaling and latency thread
Fast_Freddie
Oct 30, 2023 01:56 AM
MercenaryX2
Dec 30, 2014 07:56 AM
jid2
Oct 12, 2011 01:25 PM
goodhart
Jul 19, 2011 03:51 AM
xspsi4
78
Sep 19, 2006 07:47 AM
