Tephra V7.1 and high load
Old Sep 20, 2011, 01:58 PM
KOOLER's Avatar
Guys,
have 2006 EDM EVO9. Tephra V7.1. On idle I have logged by EvoScan load around 200. Seems to high to me. Anything I could check for being non-working?
Thanks!
Anton
Old Sep 21, 2011, 04:37 PM
evonewb29's Avatar
Thats pretty high but cant be correct. I was logging my car tonight and for 10 minutes at idle it was between 26-28. probably just an incorrect evoscan formula somewhere.
Which load are you using to collect the data from? Load 1byte or load 2byte? You should try using load 1byte if you arent already using it.
Old Sep 21, 2011, 08:42 PM
jedibow's Avatar
Originally Posted by KOOLER
Guys,
Thanks!
Anton
Check to make sure that the 1-byte conversion is the same in the evoscan formula as it is in the trphra mod options...
Old Sep 22, 2011, 03:00 AM
justastockevo's Avatar
figured it already, mut requests were changed from what was in tephra's original firmware.
shows proper loads now.
Old Sep 22, 2011, 01:31 PM
KOOLER's Avatar
MUT tables set up correctly so load is OK. Thanks to everybody!
domyz
Jul 27, 2022 11:54 AM
ekizenbe
Sep 7, 2016 12:51 PM
Rado_93
Mar 22, 2016 09:02 AM
okevolutionVIII
Jan 1, 2014 10:15 PM
Seijuro
Mar 20, 2010 11:53 AM
Quick Reply: Tephra V7.1 and high load
