Please help me
Old Sep 22, 2011 | 12:37 PM
kassir's Avatar
Please help me
Please help me
I have car evo 10 edm 2008 sst my rom 53050006
I want write 56920006 edm 2011 sst rom
I have Problems
[20:00:58.018] ECU HW part number : 1860A982
[20:00:58.034] ECU SW part number : 1860A98201
[20:00:58.065] VIN : JMBSMCZ4A9U000688
[20:00:58.065] -- unlocking ECU --
[20:00:58.065] starting session...
[20:00:58.361] requesting seed...
[20:00:58.361] sending key...
[20:00:58.720] -- uploading kernel --
[20:00:58.736] .
[20:00:58.751] .
[20:00:58.767] .
[20:00:58.782] .
[20:00:58.798] .
[20:00:58.814] .
[20:00:58.814] .
[20:00:58.829] .
[20:00:58.845] .
[20:00:58.860] .
[20:00:58.876] .
[20:00:58.892] .
[20:00:58.892] .
[20:00:58.907] .
[20:00:58.923] .
[20:00:58.938] .
[20:00:58.954] .
[20:00:58.954] .
[20:00:58.970] .
[20:00:58.985] .
[20:00:58.985] .
[20:00:58.985] -- connecting to kernel --
[20:00:58.985] kernel get version
[20:00:59.016] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[20:00:59.016] reading kernel comm buffer size
[20:00:59.016] comm buffer size set to 1024
[20:00:59.016] reading kernel flash buffer size
[20:00:59.032] flash buffer size set to 4096
[20:00:59.048] -- flashing image to ECU memory --
[20:00:59.453] -- comparing ECU flash memory pages to image file --
[20:00:59.453] seg start len ecu CRC32 img CRC32 same?
[20:00:59.469] FB01 00000000 00002000 0DD1921C DAA340E7 NO
[20:00:59.484] FB02 00002000 00001000 2F74E0AC 7C3EC808 NO
[20:00:59.500] FB03 00003000 00001000 983E77B4 A47AF7A0 NO
[20:00:59.531] FB04 00004000 00004000 E1FD7D70 19F321DE NO
[20:00:59.594] FB05 00008000 00008000 FCA3D3DA 32B46BFC NO
[20:00:59.703] FB06 00010000 00010000 B26C8C6B 6502FCAB NO
[20:00:59.828] FB07 00020000 00010000 30251448 5EAE6E33 NO
[20:00:59.937] FB08 00030000 00010000 AF352817 D6963ED0 NO
[20:01:00.062] FB09 00040000 00010000 F81FBB90 7C130F6F NO
[20:01:00.171] FB10 00050000 00010000 D76C5A51 10C44329 NO
[20:01:00.296] FB11 00060000 00010000 74480854 206A8365 NO
[20:01:00.405] FB12 00070000 00010000 B4AA59CB 0D481CD6 NO
[20:01:00.530] FB13 00080000 00010000 228F4ECD C8D4D3EF NO
[20:01:00.639] FB14 00090000 00010000 00B1DCCB 34934D72 NO
[20:01:00.764] FB15 000A0000 00010000 BBABC310 C5DBFBB7 NO
[20:01:00.873] FB16 000B0000 00010000 0CC41B2E B09CCCBC NO
[20:01:00.998] FB17 000C0000 00010000 DEAB7E4E DEAB7E4E YES
[20:01:01.107] FB18 000D0000 00010000 DEAB7E4E DEAB7E4E YES
[20:01:01.232] FB19 000E0000 00010000 DEAB7E4E DEAB7E4E YES
[20:01:01.341] FB20 000F0000 00010000 38439CF7 38439CF7 YES
[20:01:01.341] the image you are trying to flash contains changes to protected areas! exiting.
[20:01:01.341] interface close
[20:01:01.388] interface close
File Type: hex
File Type: bin
Old Sep 22, 2011 | 06:55 PM
tephra's Avatar
your not allowed to use a 2011 ROM on a 2008.
The best ROM for you is 53050009 (or my tephraxmod version of it)
its the best supported!
whos' you tuner?
Old Sep 23, 2011 | 06:53 AM
Bernhard's Avatar
What is your reason for flashing that rom to your 2008 model?
Does the 56920006 definition file contain any table that is not yet defined for your 2008 model, I doubt so? But if this is true - I am sure someone will be able to just transfer that table to your ROM as your ROM master version 5305 is IMHO the most widely used ROM.
Old Oct 30, 2011 | 04:34 PM
AIK's Avatar
AIK
I will ask in this theme.
I very much want to use 53050009, but have some problems on it - jerks at start in a hill and at active start. But I don't have these problems on 53050012. Gearbox work in a normal mode as seems to me more adequate on the second chart (12).
My car is EDM SST Evo X 2008 with TBE, 3-port, boost up (310-320 whp i think) with tuned SST torque limiter maps.
What tables in 09 I need to tune (copy from 12) to fix this problem? Thanks.
Nsk
Jul 11, 2020 02:01 AM
rrstlevo
Mar 25, 2016 12:06 PM
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
napado
13
Mar 31, 2010 01:49 AM
