v7 boost control issues
Old Oct 7, 2011 | 02:37 AM
infini_IV's Avatar
Im interested in using v7 90550001 for the big map feature but am struggling to understand the boost control features, for example RPM/SPEED to GEAR im unsure as to what it is and what its used for, searching suggests it may only be used for gear based boost control and not needed otherwise. If this is so how do i determine if im using gear based boost control, it is not an item that can be enabled or disabled so i have no idea, ive tried asking and had no answers so this suggests no one else knows what it does either.
Effectively all i wish to do is retain all the standard features of my current rom but with the added feature of big maps, im not interested in having gear based boost control or any other features and would like to know what changes are needed and what can just be ignored (ie not used)
Thanks
Old Oct 7, 2011 | 02:52 AM
Raceghost's Avatar
Speed to gear answer one:
Tephra mods, dont remember if it is switchable on, you will have a wastegate duty cycle table reflecting each gear, as well as a boost table for each gear.
There is also a 3d table for crossover points in each gear...
Old Oct 8, 2011 | 12:54 PM
infini_IV's Avatar
Thanks, allthough i didnt understand any of that, so if it isnt used what needs to be entered, seams odd that hundreds are using V7 yet no one knows what rpm/speed to gear is
Old Oct 9, 2011 | 07:55 AM
kronik5383's Avatar
the rpm/speed values for the table are set by taking your max rpm for a gear, and dividing it by the speed you are going at. eg, going 120km/h at 7000rpm on 2nd gear would be 7000rpm/120km/h = 58. this is so the ecu will know which gear you are in for gear basd WG and boost control settings.
hope that is what you wanted to know
also, if you do not wish to use gear based boost control, first off, it is used with ecu controlled boost, af you are using ecu based boost, to "disable" gear based, simply put the desired boost values in all the cells
Raceghost
Jul 29, 2016 12:04 PM
THmotorsports
Vendor Classifieds
454
Mar 24, 2013 06:31 PM
HornstarBU
Lancer Engine Management / Tuning Forums
Oct 8, 2011 09:44 PM
jdmevo123
May 10, 2010 08:19 AM
boosted hybrid
Evo 'For Sale' Electronics / Lighting / Audio
Jan 21, 2008 06:34 AM
