EvoX ACD reprogramming
Old Dec 19, 2011 | 05:37 AM
  #61
tephra's Avatar
I haz the ACD Lockup maps
some interesting comparisons to CT9A and to CZ4A_Ralliart_Tarmac to be had!
Old Dec 19, 2011 | 10:53 AM
  #62
Dragon-V's Avatar
Just looking at a few of the maps, one of the scaling looks like TPS but going to have a brake now for a bit as its doing my head in lol
Lee
Old Dec 19, 2011 | 11:42 AM
  #63
Greg555's Avatar
tephra
Did you get my PM?
Im still looking for X xml
Thanks
greg
Old Dec 19, 2011 | 03:04 PM
  #64
tephra's Avatar
none available yet...
Old Dec 20, 2011 | 03:54 AM
  #65
sba's Avatar
sba
It seems that Mitsubishi and Ralliart tuned the CZ4A in the manner that we are tuning CT9A ACD, which makes us believe that the direction is good.
But lots of improvment will be made in the CZ4A as well.
Old Dec 20, 2011 | 06:12 AM
  #66
Dragon-V's Avatar
I have noticed this as well with the maps, it looks very much like some of the tunes I have seen as well for the CT9A
Cheers
Lee
Old Dec 20, 2011 | 09:42 AM
  #67
sba's Avatar
sba
Here it is
Still in the making, but pretty much there!
Please don't ask me about it, it is not finish and i don't like to give things that can break your cars. I will test first and then...
Thank you for help: Tephra, Acamus, Dragon-V.
Old Dec 20, 2011 | 02:44 PM
  #68
discogodfather's Avatar
Excellent work guys. A lot of differences, to be sure. If that's the AYC map in the lower right, wow. It's extremely different, way more linear without that little island in the upper right and corner. Also no values to 100, I know it's 87 max but still strange.
Going from the top of your screenshot Sabin:
Lockup Reducer (A map)
Lockup % map (B map)
C Map
then on the right side going down:
????? Map
AYC Map
Is that right?
Old Dec 21, 2011 | 01:29 AM
  #69
sba's Avatar
sba
Yes, it depends on the scaling. This is what we are trying to figure it out.
C Map
????? Map
AYC Map
Is that right?
It the other way
A is % map
B is lockup reducer
C also reducer based on steering
??? we don't know what it is...
Old Dec 21, 2011 | 02:06 AM
  #70
Dragon-V's Avatar
It the other way
A is % map
B is lockup reducer
S,
I had a chat with my mate at Ralliart and he said it might be something to do with AYC and what mode you are in, he is going to have a look today at the tech stuff and let me know
Lee
Old Dec 21, 2011 | 02:23 AM
  #71
Scaling should be greater than that of the Evo 7/8/9 since the X has 2.3 turns to lock.
Older 7/8/9's had 2.1 turns to lock, so that was 756 degrees total. Divide by to get 378 degrees in one direction. Shouldn't that be the max number instead of 512 in the older tables?
For the X, it's 2.3 turns to lock so 828 degrees total on the X. So /2 to get 414 degrees in one direction, seems like the table should max out at 414.
I measured these on the car recently, don't know if it helps.
Old Dec 21, 2011 | 02:52 AM
  #72
sba's Avatar
sba
i measuread the same thing in a edm car (i asked a customer) and he told me exactly 900 degrees and that fits the numbers perfectly. I will try again.
Old Dec 21, 2011 | 03:29 AM
  #73
Just measured again, used an extremely accurate angle gauge. For the USDM X came out exactly to 828 degrees total, 414 degrees one way. Shown in the second pic is the 54 degree reading, which is 54 + 360 = 414.
Maybe EDM X has a 2.5 to one turns to lock? That would make it exactly 900. If not, maybe it is good to go beyond the mechanical limit a bit so you never run off the chart at the edge?
Old Dec 21, 2011 | 04:06 AM
  #74
sba's Avatar
sba
Yes, i see what you are saying. But when i make a scaling or something, i try to think what was in the mind of the guy who made the software.
With the scaling i made, i also have distinct, 180, 270, 360... and also bigger resolution until 40 degree. I find it right.
But this is only to make an idea. After we will be able to log a real car, we will know for sure if the scalings are good or not and remake them if are bad.
Old Dec 21, 2011 | 10:36 AM
  #75
RazorLab's Avatar
Is the ECU measuring the degrees at the same place you are?
