dual map question
Old Dec 1, 2011 | 01:25 PM
fwd_josh's Avatar
dual map question
i have seen that i can use my IC sprayer switch or my throttle to switch maps, but my question is can i wire a normal switch of some sorts to change maps? or is it strictly these 2 methods?
Old Dec 1, 2011 | 01:46 PM
hearnoevo's Avatar
switch
yes tephra V7 has this functionality.
Old Dec 1, 2011 | 01:54 PM
tscompusa's Avatar
you can wire it in also - but the question is why????????? why give yourself more work? the only other reason you would want or need to wire it in is if you had some type of meth fail safe switch map so it switches over to a fail safe.
Old Dec 1, 2011 | 02:05 PM
fwd_josh's Avatar
Just for positive reminder what map I'm currently on. I'm anticipating switching maps regularly, between an E85 and a pump map, since E85 isn't all over yet.
Old Dec 1, 2011 | 02:15 PM
bayrider's Avatar
I currently have map switching from 91 oct to 100 oct. Map switching is done via IC sprayer button on my 03 evo. I can easily tell what map i'm on by looking at the IC sprayer light on the dash. For 100 oct, all you have to do is hold down the IC auto button till the IC dash light starts blinking and then let go. It'll remain blinking to tell you that it's on the 100 oct map. Now, if you want to switch back to 91 oct, just hold down the IC auto button again till the light goes away and now your on your 91 oct map.
I hope this helps!
Old Dec 1, 2011 | 02:16 PM
usnevo8's Avatar
the wiring wouldn't be a problem..
josh i see youre finally making the big move buddy lol
Old Dec 1, 2011 | 02:29 PM
todd6027's Avatar
5v from pin 81 sensor power supply to toggle switch then from switch to adc input pin 42 .
for 8 usdm
change tephra mod options
enable alt maps master to adcof =1
Old Dec 1, 2011 | 02:35 PM
fwd_josh's Avatar
not just yet, just getting all my ducks in a row first. once i buy everything i want, i'll install and tune everything at once.
Old Dec 1, 2011 | 02:42 PM
10isace's Avatar
I thought about this too, but my ICS light blinks when I'm on the Alt map.
Old Dec 1, 2011 | 02:45 PM
fwd_josh's Avatar
that flashing light would drive me crazy....
Old Dec 1, 2011 | 02:49 PM
tiggeryellow1's Avatar
Veteran: Army
LoL... U get used to it.
Old Dec 1, 2011 | 03:03 PM
bayrider's Avatar
Hehehe... It's not that bad. Sometimes i don't even notice it.
Old Dec 1, 2011 | 04:27 PM
fwd_josh's Avatar
i would. lights in the dash are my pet peeve.
Old Dec 1, 2011 | 04:41 PM
10isace's Avatar
Get a dual gauge steering column pod, you won't even notice your fuel light
Old Dec 1, 2011 | 05:13 PM
fwd_josh's Avatar
i have the single pod on the column now, and having a CEL or 2 has motivated me to move my gauge off the steering column eventually.
